F55/F56 CravenSpeed MINI Smartphone Mount Pro Series HELP
Old Nov 6, 2014 | 05:26 AM
JohnWB's Avatar
JohnWB
I would like to fit a MINI Smartphone Mount Pro Series (with the Scissor XL cradle) to my F56, but I am in the UK and Craven do not make a Right Hand drive version and have no plan to do so. I will be getting just the Scissor XL cradle from Craven.
Would somone be able to make me a tracing of the bracket that mounts onto the rear of the Tach so i can use it to make one with the mounting point on the other side.
I realise this could be seen as taking a sale from Craven, but as they are not going to be making a RH drive version I think it should be ok (it will only be for me) any help will be appreciated.
Old Nov 6, 2014 | 06:10 AM
George 2014's Avatar
George 2014
I have a thought: Rather than try to fabricate something from scratch, why not just take the tach mount, drill a few holes in it, then use any of their modular arms and whatnot to basically "create" the mount you need. A drill press and appropriate taps and you should be able to fab up anything you need from their assortment of replacement arms.
Hope this helps.
Old Nov 6, 2014 | 06:15 AM
JohnWB's Avatar
JohnWB
Hope this helps.
Thanks for that, it may be the way I go. I will have to wait and see if anyone provides a tracing and how hard it looks to make a complete new one.
Old Nov 6, 2014 | 06:40 AM
George 2014
I can tell you that you'll need access to either a CNC mill, laser, or waterjet, then the standoff tubes that are welded to the actual bracket.
IMO, this is one of those things that would be a lot easier to buy and just modify than to fab up from scratch. Just my 2-cents. Please let us know how it goes.
Old Nov 6, 2014 | 06:51 AM
JohnWB's Avatar
JohnWB
Will do
Old Nov 9, 2014 | 03:41 AM
JohnWB's Avatar
JohnWB
Anyone able to help with the tracing so I can position the mounting holes correctly.
Old Nov 9, 2014 | 01:33 PM
hammerhands's Avatar
hammerhands
Does it matter to you to have the iPod on the left side?
Old Nov 10, 2014 | 12:24 PM
CravenSpeed's Avatar
CravenSpeed
Vendor
That is a good point. Just in case there was a misunderstanding; our smartphone mounting bracket does fit RHD MINIs, it will just still have the phone on the right side of the tach. The reason for this (and I apologize to leftys in advance) is more about the overwhelming right handedness than it is about mounting it toward the center of the vehicle.
eastport_mini
General Mini related Ads
Mar 28, 2016 08:35 PM
wheresaldo
Oct 23, 2015 10:17 AM
tag1260
Aug 10, 2015 10:41 AM
pvtryan478
Aug 9, 2015 12:24 PM
