F55/F56 Dynamic Damper question
Old Oct 20, 2014 | 08:45 PM
daffodildeb's Avatar
daffodildeb
We ordered our 2015 with the Dynamic Damper option, and have a question about it. Ours was the first car to come in with that option, and I don't think the dealership really knows the answer to our question, or maybe we're just not expressing it well. This is a question ONLY for the F56; my search brought too many answers that related to the R56 (even though I selected Gen 3).
What we want to know is can the Sport Mode be operated without the suspension stiffening? I prefer the Sport Mode as far as steering feel and throttle response, and I drive that way any time I'm alone (I did in my R56 as well). Hubby doesn't like it, though, saying that it makes the suspension too rough for him. I suspect my more adequate...um...padding makes a difference.
Is it possible to have the Sport Mode on, but have the ride the same as in the default "normal" Mode?
Old Oct 20, 2014 | 08:58 PM
Kinetic89's Avatar
Kinetic89
There is a way to configure sport mode, along with green mode.
Someone will probably chime in before I get a chance to look in my car, as I don't remember off of the top of my head, other than its in the vehicle settings.
Old Oct 20, 2014 | 09:06 PM
ScaldedDog's Avatar
ScaldedDog
Set to Sport Mode.....on the screen for Sport Mode: scroll down to the "gear" at the bottom of the page and tap the scroll button. It then gives you choices for Drivetrain and Chassis, Drivetrain or Chassis. Then take your pick
Old Oct 20, 2014 | 09:19 PM
daffodildeb
Interesting! So, logically that would also be a key-dependent his/her setting, so he could preserve his tush and I could keep my steering?
Old Oct 22, 2014 | 03:58 PM
MiniMeR50's Avatar
MiniMeR50
Was this option worth it? I'm debating between this, sport suspension, and just stock.
Old Oct 22, 2014 | 04:23 PM
tuco44's Avatar
tuco44
Yes, I really like the Dynamic Dampers, makes for a much more focussed drive in Sport. I skipped the Sport Suspension to avoid making the ride too tough. I drive mostly in Normal, use Sport about 25% of the time, and never use Green.
Old Oct 22, 2014 | 06:09 PM
daffodildeb
I honestly don't know. Ever see the movie "Rush," about Formula 1? You know the part where Nikki Lauda says he has an "educated butt," or something like that? Well, I don't. They feel the same to me. Huge difference to my Hubby. Might have something to do with my extra padding...
Old Oct 23, 2014 | 05:32 AM
RichSz's Avatar
RichSz
This.
You can definitely feel the difference in ride smoothness between Mid and Sport with this option. I also skipped Sport Suspension because I think MINIs ride on the verge of uncomfortable as is. From what I can tell, I get similar ride stiffness as SS when in Sport mode but can also mellow out the ride a bit in Mid.
Off topic but commenting from above, Green mode drains all the fun out of these cars.
Old Oct 23, 2014 | 07:16 AM
mikeymike1985's Avatar
mikeymike1985
So how are you able to make the ride the most soft/relaxed? I have DDC and noticed you can only customize the ride in sport as far as selecting drivetrain/chassis but it seems there are no options in mid or green (other than the green mode settings).
Old Oct 23, 2014 | 07:56 AM
RichSz's Avatar
RichSz
I believe it's lumped together under the chassis setting for Sport mode. It's not like you can dial it up or down at will. In Mid mode if you pay attention to how smooth the ride feels then switch into Sport mode you can feel a distinct difference.
I don't know if Green is different than Mid.
Old Oct 23, 2014 | 08:20 AM
Mosco's Avatar
Mosco
Rich is correct. Green/Mid mode have the same suspension settings. Sport mode stiffens the suspension.
That said, you are NOT able to change the base settings for each of the modes, but you can change whether or not the stiffer setting is used when you switch to sport.
Old Oct 23, 2014 | 04:11 PM
torpeau's Avatar
torpeau
I have the DDS, but rarely change the settings. However, if I'm not mistaken, with the automatic transmission version, if you move the lever to the left, you increase the engine responsiveness. Steering remains the same, and the shift points are more aggressive. Want to make a quick getaway from the toll booth or when the light goes green, just move that lever to the left.
Old Oct 23, 2014 | 08:44 PM
daffodildeb
Yes, I know. Sport mode stiffens the STEERING, as well as increases the engine response. That's true of the manual version as well, which I have. The suspension--butt feel, if you like--is a different issue. I truly can't tell the difference! There are rough roads around, and I've tried putting it in Sport after being in Mid mode. I just can't feel anything different other than in the steering. Plus, the car jumps a little ahead, which probably relates to the throttle response.
I might add, I was used to driving in Sport mode 100% of the time with my '07, but I didn't have any suspension mods, nor did I have the sport suspension.
Old Oct 24, 2014 | 03:03 AM
mikeymike1985
Thank you all for the input. I have not once used sport mode so I primarily have been driving in mid mode. I figured I should follow the break in period but if I put it in sport mode I feel that the RPM's would get too high. Any tips on proper break in?
Old Oct 24, 2014 | 08:00 PM
daffodildeb
I don't understand why you won't drive in sport mode until it gets broken in. It's a common comment, so please don't feel I'm picking on you. RPMs do NOT get too high. It really doesn't have much to do with it. Sport mode changes the FEEL of the steering--makes it a little stiffer. It also improves the throttle response time. In my R56, I found that I tended to have a bit of a problem getting a smooth shift at low speeds unless I used sport mode. A few other people made the same comment, when the R56 came out.
As for break in, generally speaking you want to vary your speeds, and RPMs. Don't plan on setting cruise control and blasting hour after hour down the interstate. More than worrying about sport mode, I'd worry about holding steady speeds. Especially for the first few hundred miles, you should be that irritating guy who doesn't keep the same speeds, especially if your roads don't make you change power settings. Nice twisties do wonders.
Drive normally! Just keep it under 100.
I'd also change the oil after about 1500 miles, even if you have to pay someone to do it for you.
Old Oct 24, 2014 | 09:21 PM
hsautocrosser's Avatar
hsautocrosser
DDC only increases the shock absorber resistance. It was estimated 10% stiffer than normal. The sport suspension permanently stiffens shocks, springs, and sway bars for an estimated 30% increase.
Tire selection will affect ride more than either of those "suspension" options. It takes a bit longer to change four wheels for differing driver preferences though.
Old Oct 25, 2014 | 12:03 AM
mikeymike1985
I don't understand why you won't drive in sport mode until it gets broken in. It's a common comment, so please don't feel I'm picking on you. RPMs do NOT get too high. It really doesn't have much to do with it. Sport mode changes the FEEL of the steering--makes it a little stiffer. It also improves the throttle response time. In my R56, I found that I tended to have a bit of a problem getting a smooth shift at low speeds unless I used sport mode. A few other people made the same comment, when the R56 came out. As for break in, generally speaking you want to vary your speeds, and RPMs. Don't plan on setting cruise control and blasting hour after hour down the interstate. More than worrying about sport mode, I'd worry about holding steady speeds. Especially for the first few hundred miles, you should be that irritating guy who doesn't keep the same speeds, especially if your roads don't make you change power settings. Nice twisties do wonders. Drive normally! Just keep it under 100. I'd also change the oil after about 1500 miles, even if you have to pay someone to do it for you.
No worries. I didn't take any offense at all. That is actually great feedback and information. This is what I love about this forum :-) I guess this just shows I am not fully educated on proper break in procedure but I will now take your advice and use sport mode tomorrow. I have not and will not use cruise control until after break in. I did take a nice drive up the mountain the other day so it was nice to see how the car handled on the twisties and it definitely helped vary the speed and RPM's. I elected to tell myself to get the oil changed early the first time. Is 1500 miles the time it should be done and then stick to the regular scheduled maintenance? Also, when you drive in sport, and since you have the Dynamic Dampers, are you configuring it to leave the suspension normal like in mid mode? Will it still allow the steering to be firm? Thanks again for your feedback!!! :-) :-) :-)
Old Oct 25, 2014 | 09:18 PM
daffodildeb
The 1500 miles is a somewhat arbitrary interval for the first oil change. It's something WE do, but I realize most owners won't, since it isn't covered under the MINI service plan. After that first oil change, we'll revert to a more normal interval, but it's still likely to include more changes than MINI will pay for under the service plan. Hubby works cheap, and we have a place to do the work. He estimates it costs $35 for the best grade of Mobil 1 and a filter. Pretty cheap insurance, I say.
I'll tell you about another car I'm familiar with, where this could have made a difference. A fellow who had recently had an engine overhaul done on his rare and very valuable British classic car (not a MINI or Mini, and not a modern car), noticed that his car had a knock. In checking further, he found that metal shavings hadn't been properly cleaned out of the cylinders, and they were badly scored. Now, I realize this isn't an entirely similar situation, and I also realize that MINI's assembly line techniques probably would have prevented the problem. I mention it, though, because an engine was nearly ruined--and major repairs are absolutely needed--because of small metal particles. I personally would prefer to sweep as many of these particles away! I'd also like to take a look at the drained oil and the oil filter to make sure nothing's going bad in a crucial time in my engine's life. I like to keep my cars for a long time. If you trade cars as soon as they're out of warranty, this might not be necessary for you.
Hubby's been getting used to the sport mode, and even voluntarily drives in it on twisties. Since I can't feel the added roughness, most likely I'll continue to drive in sport mode any time he's not with me (most of the time), and let him choose what he wants when we drive together. In about a year we'll be replacing the runflats with nonrunflats, and that will probably make a difference, too.
Old Oct 27, 2014 | 01:12 AM
mikeymike1985
The 1500 miles is a somewhat arbitrary interval for the first oil change. It's something WE do, but I realize most owners won't, since it isn't covered under the MINI service plan. After that first oil change, we'll revert to a more normal interval, but it's still likely to include more changes than MINI will pay for under the service plan. Hubby works cheap, and we have a place to do the work. He estimates it costs $35 for the best grade of Mobil 1 and a filter. Pretty cheap insurance, I say. I'll tell you about another car I'm familiar with, where this could have made a difference. A fellow who had recently had an engine overhaul done on his rare and very valuable British classic car (not a MINI or Mini, and not a modern car), noticed that his car had a knock. In checking further, he found that metal shavings hadn't been properly cleaned out of the cylinders, and they were badly scored. Now, I realize this isn't an entirely similar situation, and I also realize that MINI's assembly line techniques probably would have prevented the problem. I mention it, though, because an engine was nearly ruined--and major repairs are absolutely needed--because of small metal particles. I personally would prefer to sweep as many of these particles away! I'd also like to take a look at the drained oil and the oil filter to make sure nothing's going bad in a crucial time in my engine's life. I like to keep my cars for a long time. If you trade cars as soon as they're out of warranty, this might not be necessary for you. Hubby's been getting used to the sport mode, and even voluntarily drives in it on twisties. Since I can't feel the added roughness, most likely I'll continue to drive in sport mode any time he's not with me (most of the time), and let him choose what he wants when we drive together. In about a year we'll be replacing the runflats with nonrunflats, and that will probably make a difference, too.
Thanks so much!!! I actually started using sport mode and I love it. The engine tone is so deep it's like a growl. This break in period is gonna feel like forever keeping it under 4500 RPM's. You just feel like the engine wants to go but you have to hold back ;-)
Colt45Magnus
Aug 27, 2024 05:03 AM
donniedarko
Oct 21, 2015 01:15 PM
one73ronin
23
Sep 22, 2015 09:56 AM
Sep 11, 2015 01:15 PM
Manny_cooper
Sep 3, 2015 05:48 AM
