F55/F56 Green mode oddness
Old Jul 13, 2014 | 08:53 PM
kongjie's Avatar
kongjie
Green mode oddness
The other day I was putting around town in green mode, parallel parked and turned the car off.
Only it wouldn't turn off. The switch had no effect.
I had to take it out of green mode in order to turn it off.
Is this a feature or a bug? didn't find anything in the manual.
Old Jul 13, 2014 | 09:51 PM
sal1k's Avatar
sal1k
I usually drive in Green mode since the majority of my driving is in town, and the issue hasn't happened to me [yet... knock on wood]. but, I have had to be more "firm" with the Start/Stop toggle switch sometimes. Ensuring that I'm pressing it deeply, rather than being weak with the press in order for it to activate. Let us know if you can replicate the issue.
Old Jul 14, 2014 | 05:47 AM
RichSz's Avatar
RichSz
I don't have a Mini yet so I'm just speculating. Could it be that as you stopped the car, it shut its engine off as part of the Green feature then ignored the Start/Stop switch because it thought you were asking it to restart. In that situation, I wonder if depressing the brake or clutch (depending on your car) would restart the car allowing you to turn it off via the switch.
I didn't make that very clear, but I think I get what's happening.
Old Jul 14, 2014 | 05:58 AM
SeppTB's Avatar
SeppTB
Sounds a bit different than that. The car, in any mode, when you put it in park will turn the engine off as a normal engine start/stop (That's not a green feature, that happens in all modes unless you turn it off). Then when you hit the Start/Stop toggle once it turns off the ability to re-ignite, the climate system, and if you have HUD, it'll retract that. Hit it once more and all the rest of the electronics (lights, radio, etc) turn off as well. Sounds like none of that is happening for kongjie.
1400 miles on mine now, almost 80% in green mode, and I've never seen that kongjie =/ I'd give your MA a call, and maybe bring it in if you are near by. From what I've read on these forums most of the odder problems can be fixed by a software tweak.
Old Jul 14, 2014 | 03:11 PM
kongjie's Avatar
kongjie
No, that wasn't it. The car was clearly still running. I pressed the switch once, and the car kept running. Pressed it again, thinking I hadn't hit it squarely the first time. Then--although it made no sense to do it--I pressed on the brake and pressed the switch again. Still running.
When I take it in I'll mention this as well as my brief foray into "drivetrain malfunction" territory. Might all be software.
Old Jul 14, 2014 | 09:21 PM
IDNTFIT's Avatar
IDNTFIT
Did you try turning off the auto stop/start mode first, then hitting the engine stop switch?
Old Jul 14, 2014 | 11:17 PM
tej's Avatar
tej
Wacky! This just happened to me today. Ran some errands and thought I would hyper-mile in Green mode for the day. I got home and parked in the driveway. Tried to turn the car off, and it wouldn't turn off. I thought it was something to do with auto stop/start system. Played with the auto stop toggle switch and nothing happened.
I don't know what eventually worked but I was able to turn off the engine. I started throwing all kinds of solutions all at once. I drove backwards for 10 feet and back to my original parked position. Then tried pulling the parking brake up and down, in different positions. Eventually moved from Green to mid-mode. And thereafter tried turning off the car, and it eventually did. Total elapsed time from the first time I stopped in the driveway to finally turning off the car was only about 20 seconds.... it just sounds like I spent many minutes trying to complete this task.
I'll keep an eye on it and report back if it comes back.
Old Jul 15, 2014 | 10:52 AM
glucklich21's Avatar
glucklich21
Hmm, so I'm not the only one then. Sometimes I have to hold the stop/start toggle for a good 5 seconds before the car gets the message. It has done this on a couple of occasions between mid and green mode.
Old Jul 15, 2014 | 11:12 AM
TouchUpDirect's Avatar
TouchUpDirect
I've also had this happen 3-4 times. It always eventually shuts off after fiddling with the switch, but it's plenty weird when the car won't just shut down.
Old Jul 15, 2014 | 06:10 PM
dwdyer's Avatar
dwdyer
Happened to me today in normal mode. Car would not turn off until I had my foot back on the brake. Later tried to replicate it, couldn't.
Also have had auto start/stop start the engine when I opened the driver door. Come to a stop, engine stops. Open the door, car starts. In park.
Doesn't do that every time though.
Very odd.
Old Jul 15, 2014 | 06:57 PM
hammerhands's Avatar
hammerhands
It's not just the cooling fan running?
Old Jul 15, 2014 | 06:58 PM
IDNTFIT's Avatar
IDNTFIT
Could be a heat issue? Computer is programmed to let engine cool a bit before shut down? Kinda like a turbo timer?
Old Jul 16, 2014 | 08:20 AM
emilyanny4u's Avatar
emilyanny4u
I have only had this happen to me once in the 2,500 miles I have had the car. My husband was driving and got out to put fuel in the car. He said to me "I must have forgot to turn the car off can you reach over and do that for me." I said I would but it would not turn off until I must have pushed the off switch 10 times.
Old Jul 16, 2014 | 09:00 AM
kongjie's Avatar
kongjie
I haven't found anything in the manual that would suggest this would happen. I mean, not being able to turn the car off is a significant event, and I would think the manual would have to note it as a possibility.
Old Jul 16, 2014 | 09:06 AM
cwginac's Avatar
cwginac
Very odd.
I think I read in the manual that the engine will turn on if it doesn't think you're just stopped at a light. Opening the door should turn it on. Odd though that it will stay off when you put it into park. The battery can't hold enough charge for it to sit off like that. This isn't a Prius. (I actually turn off the auto start/stop because coming from a Prius, it's weird to me that the car has to basically turn on again. The Prius shift from electric to gas didn't happen at 0mph and was smooth)
Old Jul 16, 2014 | 09:20 AM
tripleTurbo's Avatar
tripleTurbo
How green is Green Mode
Does Green Mode give even better gas mileage than the EPA rating?
I've been assuming that Normal Mode is the sticker EPA rating. Wrong assumption? Hyper milers please chime in.
Old Jul 16, 2014 | 12:16 PM
SeppTB's Avatar
SeppTB
Hard to say as I'm not really out of the break-in period yet, but on strict highway driving in green mode, yes, green mode seems to beat sticker. I get about 44 average in pure highway, unfortunately the getting to the highway and off of it downs that quickly =) I did a 350 mile trip that was 75% highway 25% off of it and had 40.6 MPG, only 0.4 under EPA sticker estimate for highway, and that was in the first 1K miles.
Part of the green mode stuff is it'll lecture you for driving poorly, if you drive how it tells you (slow acceleration, coast well before braking, brake slowly) you should beat the EPA estimates.
Old Jul 16, 2014 | 05:38 PM
tej's Avatar
tej
If I remember correctly. The EPA fuel economy measurements must utilize the "standard" default setup. Meaning a cold start, and straight to drive. It does not take to account "Sport" or "Green" modes.
eMINI of the State
Oct 2, 2015 03:12 PM
potterstein
Oct 2, 2015 09:30 AM
MiniSMan
Sep 29, 2015 06:38 PM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
daviday
Sep 25, 2015 01:31 AM
