F55/F56 Minor Problems
Old May 5, 2014 | 04:11 PM
GregoryK's Avatar
GregoryK
Minor Problems
On day 2 noticed a scratch on the horn button on the steering wheel. Must have happened at the factory.
When I washed my car yesterday noticed that one of the robots had had a leaky caulking gun and while sealing all the joints around the back hatch (check what looks like welds they are caulk) dropped some around the interior frame - where the water runs. This was in turn painted and after I touched it is now a white spot. It's a drag because you can't really ask for the whole interior trim to get painted all you are going to get is a touch up. There are 2 places this happened one is mainly covered by the rubber gasket.
Attached Thumbnails Minor Problems-dsc02145.jpg   Minor Problems-dsc02150.jpg   Minor Problems-dsc02152.jpg
Old May 5, 2014 | 04:16 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
Hmmm Im surprised they didn't catch that after inspection on all your items you mentioned. Are you going to bring it up too the dealer?
Old May 5, 2014 | 04:20 PM
GregoryK's Avatar
GregoryK
Zippy. Did that today they are going to order a new cover and touch up the paint. But it will always be that...a touchup.
Here's an out of focus pic of the spot. The one in my first post is not scratched. Be careful though this stuff is soft and the paint will come off!
Old May 5, 2014 | 04:30 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
I see what you mean about the seam sealer. They really goop that stuff on! As far as touch up is concerned.. Im not a fan of it either. I suppose the seam sealer is still very soft yet and hasn't cured much.. The main thing is as long as your happy with what ever they do for yah! You have a nice ride! I see people are posting there washing there new MINIs. I thought you weren't suppose to wash them for a good month!
Old May 5, 2014 | 04:39 PM
GregoryK's Avatar
GregoryK
Well the car was built a month ago....
Old May 5, 2014 | 04:40 PM
VYPUR's Avatar
VYPUR
Hahaha good point.
Old May 5, 2014 | 04:49 PM
GregoryK's Avatar
GregoryK
That caulk will never harden up anyway. Paint over a soft surface....watch out.
Old May 5, 2014 | 08:05 PM
ZIPPY "S"'s Avatar
ZIPPY "S"
The seam sealer should firm up a bit more.. But most seam sealers require some dry time before painting. Other wise paint will not adhere properly to the sealer nor will the seam sealer dry properly. Seam sealer needs to breath a bit (cure) before painting over it! Just makes me wonder how fast these are being built in the factory.
Old May 6, 2014 | 05:06 AM
GregoryK's Avatar
GregoryK
Zippy. I'm sure it happens the same day! You can feel how soft it is underneath.
Old May 6, 2014 | 04:03 PM
torpeau's Avatar
torpeau
I pushed on this caulk, sealant(?), but I didn't squish or squeeze it and it seemed firm. My car was completed on March 26th, so maybe it had time to cure/harden.
Old May 6, 2014 | 04:13 PM
GregoryK's Avatar
GregoryK
Yes mine is reasonably stiff where it looks like a weld -its the other spots where it is very soft.
Old May 6, 2014 | 05:11 PM
MotorMayhem's Avatar
MotorMayhem
I did the same and found the same results as Torpeau. All weld lines felt very firm and solid.
Looking at the OP's original photos I see the spot of caulk he is talking about next to the nice weld line which I do not have on mine. All of the weld lines on mine are fairly smooth and and the area around them is clean without any bumps or apparent drops. I think you called right Greg that the robots may have had an off moment and squirted too much stuff on the car's body.
Old May 6, 2014 | 05:18 PM
GregoryK's Avatar
GregoryK
MM also from my limited knowledge of industrial grade caulking they are always 2 part and mix in the gun. that's why they can paint right over them as they are a chemical set.
What I suspect happened with mine is that one of the 2 parts dripped and that is why it is so soft under the paint. Never cured....
Old May 6, 2014 | 05:26 PM
MotorMayhem
that sounds logical to me as well from what I know the process Greg.
LostDenverite
Feb 10, 2016 04:59 AM
Ollie625
Nov 15, 2015 06:57 AM
embiggenedmini
Oct 15, 2015 12:36 PM
Sep 2, 2015 09:05 AM
mike_
Sep 1, 2015 09:35 AM
