F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Wiring diagram DCT transmission
Old Feb 15, 2026 | 08:21 PM
Czptp Px's Avatar
Czptp Px
Would anyone have access to wiring diagram for the Getrag DCT automatic transmission (7dct300)? I have a short-circuit to B+ or line disconnect to the transmission pressure sensor 1. I'm trying to trace back to the short. Tested wire for ground. Signal and Reference line have same voltage, not 5V. Wiring loom appears intact. Might be another sensor on the same circuit drawing it down?
420C09 Pressure sensor 1: Short circuit to B+ or line disconnection signal
420C0A Pressure sensor 1: Signal exceeds upper threshold value
I have ISTA. I only got the diagram of the Sensor itself, missing the other things on the same line. If someone has the alldata Wiring diagram, that would be awesome.
Old Feb 19, 2026 | 07:00 PM
Czptp Px's Avatar
Czptp Px
With ignition on, engine off - supply line is 5.03V, Sensor is 4.88V and ground is 0. Both pressure sensor connectors measure the same. Thought of swapping the sensors physically but the good one is difficult to access, bad one is at the bottom of the car. Unfortunately, loom also won't reach to just swap connections as best I can tell although the lower line can reach the upper sensor.
Thought was to disconnect sensor 2 connector, plug in sensor 1 line
Old Mar 4, 2026 | 03:55 AM
67moris's Avatar
67moris
I’m having the same issues
67moris's Avatar
67moris
Keep me posted thanks
mkov608
Feb 21, 2024 02:04 PM
F5666
Electrical
Apr 20, 2023 04:43 AM
pollito
Oct 1, 2022 08:36 AM
Gambedegallina
Nov 27, 2019 04:45 PM
Bodacious
Jul 9, 2018 07:04 PM
