F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
2015 Mini Cooper S DSC or ABS Brakes problem
Old Nov 24, 2022 | 12:26 PM
jmsmeraz@gmail.com's Avatar
jmsmeraz@gmail.com
Its being doing this for several days now. While driving normal, a sudden throttle lift causes the car to brake by itself. Also a sudden change in direction triggers the same thing. It stays braking for a few seconds and slowly releases the brakes. Getting to stopsigns or stoplights its now a problem, the car stays braking for a while after releasing the brakes. No warning or check engine light at all of any kind. No faults in the scanner. If someone knows anything about this please help. Im willing to try fix it myself if possible.
Old Dec 7, 2023 | 06:41 PM
mceprda's Avatar
mceprda
did you find out what it was??
im having the same exact issue…. They want to replace the dsc/ hydro unit for $5000
Old Jan 23, 2024 | 06:34 AM
deba89's Avatar
deba89
Hi! I'm having the exact same issue, but no idea on how to solve this. Any help will be HIGHLY appreciated.
Old Jan 23, 2024 | 06:46 AM
mcepe's Avatar
mcepe
Waiting….
I am changing the DSC unit on the 28th for a used one.
I’ll let you know what it happens after that:/ used one for $1800 😭
Old Jan 23, 2024 | 07:59 AM
deba89's Avatar
deba89
Thank you for your response. Have you tried disconnecting the DSC in order to determine if that's the cause?
Old Feb 5, 2024 | 09:11 AM
deba89's Avatar
deba89
Hi! Did this replacement fix the issue?
Old Feb 17, 2024 | 04:28 PM
deba89's Avatar
deba89
Hi! After hours of browsing the web, I came to the conclusion that this may be the only thread that is about this specific issue.
Still haven't found the porblem and mi car keeps applying brakes in the situations described above.
Old Jul 22, 2024 | 03:09 PM
Jmouse's Avatar
Jmouse
Hello @mcepe and @deba89 , I just got a 2015 F55 with what seems the same issue. Any news on cause/cure?
Old Jul 22, 2024 | 04:28 PM
mcepe's Avatar
mcepe
Still having issues
well, I am having a DSC unit replaced next month, I’ll let you know if that fixes the issue :/ it cost me $2000 … not nice but I hope it’s worthy
Old Jul 22, 2024 | 06:58 PM
Jmouse's Avatar
Jmouse
Thanks for replying so quickly!
I'm taking mine to MINI of Tampa Bay tomorrow. It's been raining buckets around here, so I hope they can test under the right conditions.
Old Jul 22, 2024 | 08:52 PM
deba89's Avatar
deba89
@Jmouse hi! I finally replaced de DSC unit and everything is working fine now. I was able to buy a used one for $600 and the programming costed me $300.
Old Jul 23, 2024 | 07:39 AM
Jmouse's Avatar
Jmouse
Thanks for the input, @deba89. I'll keep you posted from my meet at MINI.
This being a serious safety issue I wonder if there is an internal bulletin addressing it.
Stefanor
Wheels/Tires/Brakes
Jan 2, 2024 11:06 AM
theblackfalcon
Feb 8, 2016 06:54 AM
sm2dan
SCCA Solo and ProSolo
Oct 30, 2007 08:35 PM
tigertiger
Jul 18, 2007 02:45 AM
MisterCooper
Dec 5, 2006 04:24 PM
