F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Check engine light with several codes popped up yesterday....
Old Oct 9, 2021 | 06:18 AM
Boarding00n's Avatar
Boarding00n
So, everything seemed fine and yesterday morning when I started the car, bam check engine light on and message on screen pops up. 2015 Cooper S 2 door 6 speed
I used 2 different scanning tools. Also, oil and filter is only a month old with about 1k miles on it.
I am very short on time at the moment due to work, so I was wondering, what are the codes, how severe is it, can I still drive for a bit before fixing, is this going to cause other problems if i continue to drive the car, where are these parts located, more than one part?
Thank you very much for the help!!!
Old Oct 9, 2021 | 08:23 AM
Boarding00n
so, I guess this is due to a exhaust and or camshaft vanos solenoid, those solenoids would be different part numbers I assume, correct?
Old Oct 9, 2021 | 10:01 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
I had a similar code on my 2012 Clubman S. Replaced both VANOS solenoids and it went away.
Looks like you need #7 here (same part for intake and exhaust):
https://www.realoem.com/bmw/enUS/sho...diagId=11_5504
Old Oct 10, 2021 | 05:14 PM
Boarding00n
ok, one better LOL
So, the check engine light popped on, thursday morning. I have driven it, thur, fri sat no issues, sun went to work no issues came home no issues, when to the park and it stalled out on me when i put it in neutral.
it starts right up and I can drive it with a little slugginish which goes away with high RPM but once I pop it in neutral it dies out.
ran scan tool again and this time I also got a new code P00BD, seems to be a mass airflow issue.
now, can this be a issue to the mass flow due to driving with the camshaft and exhaust vanos solenoids being shot and the mass airflow sensor getting dirty?
thank you
Old Oct 12, 2021 | 05:00 PM
Boarding00n
hey and thank you for replying.
is it just part 7 or part 6 and 7?
also, the one in the picture is for the cam shaft?
Old Oct 12, 2021 | 05:03 PM
Boarding00n
that part looks like the knock sensor and not a vanos solenoid, or am i wrong?
Old Oct 13, 2021 | 03:24 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Be honest with you, I’m not sure. The vanos system on those engines is completely different from the N18 engine.
#7 is labeled vanos actuator in the descriptions
Old Oct 13, 2021 | 05:04 PM
Boarding00n
so, did you replace solenoids or actuators?
Old Oct 14, 2021 | 03:25 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
On the N18, there are only solenoid valves:
https://www.realoem.com/bmw/enUS/sho...diagId=11_4586
Old Oct 14, 2021 | 01:44 PM
Boarding00n
How do I know which engine my mini has?
Old Oct 15, 2021 | 09:55 PM
renchjeep's Avatar
renchjeep
Under the hood you will find a sticker that specifies the emissions equipment on your MINI. On that sticker there will be a long string of numbers, and within that string will be B46 for the regular MINI S, and for the JCW B48. This is what I know from experience, but if you do a VIN search online, that should also indicate which engine your car has....or at least which engine it had when it left the factory.
ILMM
Sep 22, 2021 08:02 AM
CHRISTIAN ALMANZA
R55 :: Clubman Talk (2008+)
May 21, 2021 08:09 AM
redlinealley
Aug 17, 2020 07:35 AM
lai8869
Jul 13, 2019 12:08 AM
