F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Help! has anyone removed/replaced wheel bearings before?
Old Aug 25, 2019 | 02:36 PM
vid401t's Avatar
vid401t
Hey guys,
Long story short, got the JCW BBK and went to install (2016 Mini Cooper S F55), unknowing to me, my torque wrench no longer clicks and I ended up over tightening the rotor bolt that holds the rotor to the hub.
Screw was stripped as well as the mount hole. I came to terms with having to shell out $300 for a new front wheel bearing.
However, I'm not sure of the install procedure. I removed the four bolts in the back but there is a collar bolt that I think I also need to remove?
I tried to find instructions and found this: https://www.newtis.info/tisv2/a/en/f...ing/1Vncs8NL6Y
Do I really need a custom tool like shown in the link above to replace the bearing? Is there anything else I can do? Has anyone done this or have a DIY that I can follow?
I also found this link which just says to press the brake pedal down all the way but not much more info: https://www.newtis.info/tisv2/a/en/f...kle/1VnXjwG7My
Help!
Old Aug 25, 2019 | 03:59 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The two procedures are similar, just need to make sure the hub doesn’t rotate when trying to remove the collar bolt. Seems the easiest technique would be use if and assistant to press the brake pedal to hold the hub.
Old Aug 26, 2019 | 12:59 PM
Capt_bj's Avatar
Capt_bj
that bolt that holds the rotor to the hub is totally un necessary ... it just holds the rotor in place while the wheel is off and provides no 'strength' to the brake system.
Many folks have trashed the bolt trying to get it off when replacing rotors and just left it off. Simply be careful that the rotor is seated flat when you put the wheel back on. It is the wheel bolts and the wheel that hold the rotor in place for braking purposes.
Old Aug 26, 2019 | 04:01 PM
vid401t's Avatar
vid401t
Thanks guys,
Very interesting capt_bj, I didn't know that. Yeah it seemed short for a bolt that was really important.
Glad to know that even if I stripped it, I can still proceed with the install and have functioning brakes.
Cheers guys
Old Aug 28, 2019 | 11:53 AM
TVPostSound's Avatar
TVPostSound
Originally Posted by vid401t
Thanks guys,
Cheers guys
That bolt keeps your rotors from flopping around in case of a loose wheel.
Meaning your brake pedal will go to the floor while trying to stop if/when your wheel loosens on the road.
Old Oct 15, 2019 | 10:12 AM
Lex2008's Avatar
Lex2008
xed
Old Oct 18, 2019 | 11:26 AM
Yupetc's Avatar
Yupetc
You don't need to replace the whole wheel bearing for one stripped bolt stuck in there. You can drill it out or use a back-off kit to get that bolt out. And if the thread is messed up, you can re-tap it with a slightly larger hole with new thread pattern and make do. Just gotta remember to use a larger bolt with the correct pattern in the future when dealing with this hub alone.
NealDePape
May 7, 2023 02:51 PM
mark malley
Jul 20, 2015 03:08 PM
ryanleeis
May 5, 2013 07:50 PM
GoinCrzyWanaCom
Mar 15, 2011 09:40 AM
nkatsim
Oct 31, 2010 07:43 PM
