Drivetrain Wheel Hub replacment???
Old Oct 30, 2010 | 09:02 AM
nkatsim's Avatar
nkatsim
After I rotated my tires I noticed one of the front lug bolts was stripped and could not be reinstalled.Do i need to replace the hub? Thanks...
Old Oct 30, 2010 | 11:59 AM
RicardoV's Avatar
RicardoV
If the hub threads are stripped, i.e., try another bolt in the same whole, then replace the hub. If you just stripped the bolt, then you might try a thread restorer tool or the lug bolt or just buy another bolt.
Hub replacement is relatively easy to DIY, the only special tools needed are a 32MM socket for the axle nut and a 3 jaw bearing puller in case it is rusted on to the wheel carrier. All of this can be borrowed at a local AutoZone or Advance Auto, etc. Make sure you have plenty of your favorite penetrant on hand to lube the axle nut and the four 13MM (I believe) bolts on the back side of the hub.
You will find that an assortment of wobble extensions, impact wrenches, and 3/8 drive sockets will make the job go easier because of the tight quarters.
If it is not too stripped, i.e., only the first thread, than you may want to try a thread restorer, which can also be borrowed. But ultimately, I would reset back to my first answer above.
Old Oct 30, 2010 | 12:04 PM
RicardoV's Avatar
RicardoV
one more thing...
Also, always start the bolts by hand, never with an impact wrench, to avoid this in the future.
Old Oct 30, 2010 | 01:10 PM
nkatsim's Avatar
nkatsim
Wow! What a great reply and help. Thank you very much!
Old Oct 30, 2010 | 01:29 PM
nkatsim's Avatar
nkatsim
Oh, is it a good idea to replace the bearing as well or no...thanks again,
Nick
Old Oct 30, 2010 | 02:11 PM
Capt_bj's Avatar
Capt_bj
On a GEN1 the bearings were not sold as a sep' part, only as part of the hub assm'bly. I suspect same applies to GEN2
Old Oct 31, 2010 | 05:42 PM
tintman718's Avatar
tintman718
The hub & bearing are a sealed unit. I wouldn't play with the threads, just replace the unit.
Old Oct 31, 2010 | 06:27 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've got the hub/bearing assembly in stock if you want one.
Old Oct 31, 2010 | 07:43 PM
nkatsim's Avatar
nkatsim
Hey Way,
Can you pm me a price...
Nick
eliseo1981
Jan 28, 2021 02:45 PM
JPMontes3
Aug 23, 2015 01:26 AM
Powershift
Aug 16, 2015 05:14 PM
sabjcw
Aug 14, 2015 07:40 AM
