F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Sitting on the lot for a prolonged period -- first oil change when?
Old Apr 14, 2019 | 05:00 PM
reidmefirst's Avatar
reidmefirst
I bought my car with the B46 motor after it was sitting on a dealer lot for about 10 months (it was built 11 months ago, in May 2018). I'm sure there will be very differing opinions on this question but I'll ask anyway: is it better to change the oil after ~1 year of life, or better to wait until I've racked up more miles on the car? I've only owned the car for a few weeks and have just 500 miles on the odometer, 100 or so of which were from dealer test drives. I always hear rumors that vehicle manufacturers use a break-in oil with some wacky additives for the first fill, and that it is better to let those oils do their thing for a bit...
I also wonder if anyone has an inkling as to what kind of oil MINI uses for the factory fill? Worst case, I might pull a sample for analysis by Blackstone to see how the oil composition is doing after a year, would be helpful to know what kind of oil it is, of course. I guess to do that, I'll have to figure out how to pull a sample from the motor, grrrr this lack of oil dipstick!
Old Apr 14, 2019 | 05:03 PM
N0B0DY's Avatar
N0B0DY
If it was bought as a new car, the current oil change interval is 10,000 miles or 12 months, and it should be included with your purchase for 3 years 36K miles.
Old Apr 14, 2019 | 09:06 PM
Fly'n Brick's Avatar
Fly'n Brick
With the strongest forum wide recommendation, change oil every 5K regardless. Also, that's a good time to rotated the tires.
Old Apr 21, 2019 | 08:53 PM
TVPostSound's Avatar
TVPostSound
Mine was the same, my first oil change was at 1000 miles!! 3 months after buying it.
I was surprised.
You will get an oil change reminder may 2019, Dealer will gladly service it under the plan.
Old Apr 22, 2019 | 04:11 PM
Capt_bj's Avatar
Capt_bj
I bought an R59 that sat on the lot for over a year
dealer had changed the oil at the 12 month mark as required under the standard maintenance plan. I changed it 3000 miles after delivery and went to the factory schedule after that
even Jiffy Lube has given up on trying to convince folks the factory recommendations are bad . . . .
Old Apr 22, 2019 | 05:21 PM
TVPostSound
Dealers are pretty generous, even if you come in 2K miles early, they will service it under the plan.
Caterpillaraoz
Jan 5, 2018 02:29 PM
gary87xj6
Jan 26, 2013 04:13 PM
SooperCuperErik
Nov 29, 2012 05:46 AM
Hobie44610
33
Mar 14, 2011 10:07 PM
Sullivan'sDaddy
Jul 13, 2003 11:05 PM
