F55/F56/F57 Stock Problems/Issues Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F55/F56 MINI Cooper AND Cooper S models.
Squealing from gearbox (I think)
Old Dec 4, 2015 | 12:01 AM
MidnightF56's Avatar
MidnightF56
This noise has begun happening when my clutch starts engaging a gear, be it 1st or 2nd. The sound isn't there with the clutch all the way in, or with it all the way out.
The interesting thing is that it ALSO happens completely out of gear when I start the engine, and also when the engine starts itself after an auto-stopstart. It happens even if I re-start the engine by turning off the auto-stopstart switch (which means my foot is completely off the clutch pedal at all times).
Any ideas? apologies for the crappy video, but you can clearly hear the sound in the first half.
Old Dec 4, 2015 | 02:59 AM
hammerhands's Avatar
hammerhands
I can't really hear it.
Here are a couple of other squeals:
This guy thinks it's coming from the engine. No resolution.
https://www.northamericanmotoring.co...eal-whine.html
This was mine, it was a malfunctioning pressure relief valve, the pressure was being released through the oil filter. I had a drop in the oil level, too. It definitely sounded like the engine, but low in the engine.
https://www.northamericanmotoring.co...erent-one.html
No noise here, no resolution:
https://www.northamericanmotoring.co...nsmission.html
Old Jan 16, 2016 | 02:47 PM
mopar2ltr's Avatar
mopar2ltr
Squealing issue
Mine is doing the same thing the dealer believes it is the crankshaft bearings and may have to replace the engine,transmission, turbo the car only has 7k miles on it
Old Jan 16, 2016 | 07:03 PM
MidnightF56
Hi Mopar, when does your car make this noise?
Do you have any videos of it?
Anything you could contribute would help me, as my dealer is still in the dark with regard to this issue. Thank you.
Old Jan 17, 2016 | 04:53 AM
mopar2ltr's Avatar
mopar2ltr
Noise
It does it intermittently mainly in 1st and 2nd gear. When you go to accelerate it sounds like a slipping belt then when you press the clutch it goes away let off the clutch it comes back. They think it is a crankshaft bearing failure I should hear something this week as for videos I have a few but they are horrible quality. I was able to show the dealer the problem after several visits. There is another thread on here that has videos posted search for
( High Pitched Squeal ) That's what it sounds like
Old May 24, 2018 | 03:19 PM
NavyET's Avatar
NavyET
What was the final resolution? Mine just started doing this exact thing but I had the recall fix awhile back for the crankshaft bearing.
daonlyillwiz
11
Jun 8, 2024 11:55 AM
ottobomb
Off-Topic :: Autos
Jan 10, 2016 08:30 PM
wdavidhicks
Dec 1, 2015 03:41 PM
GregoryK
Nov 30, 2015 06:43 PM
TXcooper04
Nov 25, 2015 07:53 AM
