F54 :: Clubman Talk (2015+) MINI Cooper Clubman and Clubman S Discussion
F54 Can wheel spacers be used?
Old Feb 24, 2020 | 11:47 AM
wagon4me's Avatar
wagon4me
Greetings! I have the opportunity to get rims for free (20inch), but I think ET may be 34mm. If that is the actual case, could 10mm spacers be used to get into the “normal” 44mm range as it exists with the OEM 17inch rims? Or am I missing something and overthinking?
Old Feb 24, 2020 | 12:24 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you are starting at 34mm, adding 10mm spacers would take the effective offset to 24mm.
Old Feb 24, 2020 | 12:46 PM
wagon4me's Avatar
wagon4me
Spacers
Thank you for reply...so no go? Just try rims as they are and see if anything rubs? Only reason I am wondering is that I remember seeing rims at ECS tuning for the minis with ET of 34 or so.
Old Feb 24, 2020 | 01:20 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
I believe the OEM F54 Clubman wheels are 17x7.5 +54 or an 18x8 +57
What is the width of the wheel? Also, not sure what size tire you would put on a 20" wheel....
This tool is pretty helpful when comparing wheel and tire sizes:
https://www.wheel-size.com/calc/
Old Feb 24, 2020 | 01:51 PM
wagon4me's Avatar
wagon4me
Spacers
Good question on width. I’ll check tonight and post answer. I know I’m going a bit into uncharted territory with the 20’s...but they are free. The bolt pattern is 5x112, so that’s a start.
Old Feb 24, 2020 | 01:58 PM
On the size you will be ok. The New F54 and F60 will fit the big wheels, Make sure 66.6CB. Lots more room then other older MINIs. just have to watch brake clearance if you have BBKs or aftermarkets and that offset.
Old Feb 24, 2020 | 03:11 PM
wagon4me's Avatar
wagon4me
Spacers
Thank you for the encouraging news ECStuning! I have a 2017...would that be considered “new”? What’s the 66.6CB? I’ve tried to do a search, just haven’t been able to find good info on 20in wheels and potential issues.
Old Feb 24, 2020 | 09:20 PM
wagon4me's Avatar
wagon4me
Ok. I have to correct the size. The wheels are 19inch, have 255/35-19 tires now. So according to ECStuning, diameter will fit. But will the offset of 35 work? Where on rim would I find the exact offset? Currently they are on a 1996 M-B SL500. They are aftermarket and I didn’t see anything for a 19inch rim, just 17 and 18. Any ideas if they will fit?
Old Feb 25, 2020 | 03:24 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
What is the width of the wheel? I think you’ll be tight with anything over 9”. And that tire size seems very wide for an F54.
Sometimes “free” isn’t always worth it...
cmt52663's Avatar
cmt52663
That refers to the center bore of the wheels, where they meet the hub. If the 19" wheels have a larger center bore, is is possible a hub centering ring might be used. If the new wheels CB are smaller than 66.6, machining will be needed.
The offset difference means the new wheels center line would be about 20 mm further from the hub mating surface than the OEM wheel - which is 3/4 of an inch pretty near.
Cheers,
Charlie
Old Feb 25, 2020 | 11:01 AM
wagon4me's Avatar
wagon4me
Thank you so much for the information, Charlie!! I’ll start measuring things this week and see what’s what. More things to think about than I anticipated!
troyegly
Nov 13, 2014 05:55 PM
2fysh
11
Sep 28, 2013 12:20 PM
Mini SUV
Suspension
Jun 30, 2010 02:04 PM
gt2qq0
Tires, Wheels, & Brakes
Mar 22, 2009 08:46 PM
DyeLooper
Feb 1, 2008 02:08 PM
