F54 :: Clubman Stock Problems/Issues (2015+) Discussions related to warranty related issues and repairs, or other problems with the OEM parts and software for F54 MINI Cooper and Cooper S MINIs.
Radiator refill
Old Jun 17, 2025 | 09:52 AM
indian4dirt's Avatar
indian4dirt
Radiator refill
hi all...
i have a 2011 Clubman S. just replaced the gaskets on my oil filter housing.
in filling the radiator, my manual tells me to bleed coolant till it flows out from the bleed screws. it shows pics of the bleed screws in the Mk1 set up but not my Mk2... i don't see any. can somebody tell /show me where they are in a MK2?
thanks in advance.
Dave
Old Jun 17, 2025 | 01:04 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Save yourself some grief, and try to get hold of a vacuum coolant fill tool.
Something like this:
Amazon Amazon
Old Jun 18, 2025 | 08:42 AM
indian4dirt
my MK2 doesn't have an access to the radiator. i should do the vacuum on the reservoir bottle?
Old Jun 18, 2025 | 09:46 AM
WhatV8's Avatar
WhatV8
That would likely be your most reliable route. I actually pressure filled my system through the lower reservoir line till I got coolant back out the upper line. I then followed the car's coolant bleed process with the car running through its programmed process. After that I only had to top off the reservoir once after driving for a few days. Actually easier than expected when reading through the published methods for bleeding our cars. YMMV, good luck.
Old Jun 18, 2025 | 10:13 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Yes. It isn't actually an overflow / reservoir tank, but part of the pressurized cooling system.
Old Jun 19, 2025 | 01:32 AM
indian4dirt
how do u pressure feed the system?
what do u use?
Old Jun 19, 2025 | 10:01 AM
WhatV8's Avatar
WhatV8
what do u use?
What I did was use my Mityvac vacuum/pressure pump and used in reverse. Here is the kit I have: Mityvac MV8500 I filled up the reservoir bottle with coolant, plugged it into the lower line of the reservoir tank that goes back to the engine, used the Mityvac on pressure to force the fluid out back into the coolant system. I kept pumping in coolant till the coolant fed back into the upper line of the reservoir tank. It was a little slow and took several refills of the bottle, but worked great.
Old Jun 20, 2025 | 09:59 AM
indian4dirt
found a crack in my reservoir bottle at the upper hose spigot.. thats why my vacuum tested faltered. attempt #2 when parts come in.
Old Jun 23, 2025 | 10:25 AM
WhatV8's Avatar
WhatV8
That would certainly create issues with the cooling system. Hope all goes well once the new parts are in place.
wreed88
Jun 15, 2022 01:40 PM
poms302
Aug 29, 2015 06:14 PM
JAB 67
42
Aug 27, 2013 07:55 AM
maurola
Nov 25, 2008 06:41 PM
bobbymcb
Nov 20, 2006 06:18 PM
