Electrical Removing tail lights...
Old Mar 27, 2007 | 03:38 PM
SNEEEZY - Erika's Avatar
SNEEEZY - Erika
Rattle Can Queen!!!
How????
Old Mar 27, 2007 | 04:09 PM
JAB 67's Avatar
JAB 67
Very easy. Remove cubby access covers. There is a nut on a captive bolt that needs to be removed, then you unclip the wiring harness, and the light will slip out. It is infinitely easier to do with one of those ratcheting box wrenches, I don't think there is room for a socket wrench.
Old Mar 27, 2007 | 05:27 PM
SNEEEZY - Erika
Rattle Can Queen!!!
Thanks!
Discovered that the nut is 10mm in case anyone is wondering...
Are there OEM tail lights available that don't have the red lens?
Old Apr 20, 2007 | 07:53 PM
OutMotoring's Avatar
OutMotoring
Vendor - 15 Years
on the new gen 2 cars you have to carefully pop off the chrome trim around the outside of the lens and remove the screws that hold the lens to the body...
that is assuming you meant that you wanted to remove the whole lens and not just the bulbs....
Old Oct 31, 2008 | 12:33 PM
c615586's Avatar
c615586
Aaron--
Can you elaborate on how to remove the tail lights. I can barely reach them from the cubby hole inside the boot.
Old Nov 2, 2008 | 08:22 AM
benji_mini's Avatar
benji_mini
it is quite easy. if you use something (very very carefully) and pry the chrome taillight ring off, you will reveal 3 torx screws, size T20 i believe. unscrew these, reach in from the access hole and unclip the wiring harness, and push from behind and the light is free. simple as that.
Old Nov 3, 2008 | 05:30 AM
OutMotoring
Vendor - 15 Years
Yes, that is correct...
Old Feb 8, 2009 | 09:25 PM
kerikino's Avatar
kerikino
if anyone reads this... i'm trying to pry out my taillight so i can workout a dimple in the body on my 2002 r50 MC. i'm using a flathead with some elec tape. maybe i'm just being overly paranoid, but it seems like the lense is starting to crack as i pry. any advice? where to start prying first?
something about prying the chrome ring, but as far as i can tell the chrome ring is underneath the lens, looking from the exterior
Old Feb 8, 2009 | 10:06 PM
dwf137's Avatar
dwf137
^you're in the 2nd gen section...
Grizld700
Nov 8, 2016 05:14 AM
smarsha11
Aug 26, 2015 06:21 AM
WayMotorWorks
Aug 25, 2015 10:01 PM
greekzilla
Aug 23, 2015 03:44 PM
