Electrical my dash lights, turn signals and AC have gone out
Old Jul 18, 2005 | 03:57 AM
SpiderX's Avatar
SpiderX
Is this just a fuse?
Old Jul 18, 2005 | 04:28 AM
Mugami's Avatar
Mugami
Coordinator :: River City Minis
Dont know spider mine did that about month ago for aprox 20min during a drive.. then came back on near the end of it. This was when i was leaving work (5:40 am) and still dark.. headlight were working but no dash, Didnt really check the AC cause i dont use it that early in the morning. When i got two turns from home the dash lite up. So it may not be a fuse.
Old Jul 18, 2005 | 05:12 AM
SpiderX's Avatar
SpiderX
Mine went out and then I looked at some fuses and when I restarted the car it all worked and then last night it went out again.
Old Jun 12, 2006 | 12:44 PM
jab's Avatar
jab
Anybody having this problem? My dealer told me it was due to my aftermarket ICE LINK. Sounds bogus to me, just wondered if others have had this problem.
Old Jun 12, 2006 | 12:56 PM
Motor On's Avatar
Motor On
Check fuse first; ICE LINK has been known to cause some pretty weird gemlins, including throwing SES codes, screwing up guages and the like, remove it and after a few starts (if not the first) if the ICE LINK was the culprit everything should go back to normal.
Old Jun 12, 2006 | 01:02 PM
jab's Avatar
jab
I checked all the fuses. I see they no longer recommend these for mini's, nor does the company sell them. Is there anything I can do to salvage the unit?
Old Jun 12, 2006 | 01:08 PM
Motor On's Avatar
Motor On
Dunno; could ask around in the Nav. & Audio section for someone eho has some experiance; I'm not sure as to what part of it actually causes the trouble.
Old Jul 2, 2006 | 11:31 AM
cooperdude's Avatar
cooperdude
Might be a BC1 control module, my car has done that before.
Old Jul 3, 2006 | 01:49 AM
Mugami's Avatar
Mugami
Being the original post is over a year ago it may been fix or the problem as later i found for mine is the ground for the Parking brake. If your car is running with all lights on and you move you Parking brake up just a little .. all the lights will go out. move up or down a little from that spot and they will all come back on.
Old Jul 3, 2006 | 05:08 AM
SpiderX's Avatar
SpiderX
mine was when I threw a belt the belt chards severed the AC wiring at the base......
Old Aug 16, 2006 | 03:09 PM
JuniorMint's Avatar
JuniorMint
This exact thing happened to me, and all i did was disconnect the battery for an hour or two, its all good now, give that a try
Dec 23, 2015 10:36 AM
wkp1219
Nov 13, 2015 07:52 AM
HCClubbie47
R55 :: Clubman Talk (2008+)
Aug 24, 2015 02:16 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
nismo4life
Aug 5, 2015 08:31 AM
