Electrical NCS Expert v4.0.1
Old Apr 19, 2024 | 12:20 PM
athemiya's Avatar
athemiya
NCS Expert v4.0.1
Hi guys.
I have been trying to reprogram a replacement ECU for a MINI R60 COUNTRYMAN (R056-14-07-500/DEV CODE: R60).
  • I have the correct K+DCAN cable, with the switch in the correct position.
  • INPA reported connections to the engine successful
  • The Chassis & VIN FA/FG were read successfully by NCS by following the steps documented in the next bullet point
  • I followed a PDF named: NCS_DIY.pdf - which was successful at all stages, without any major errors, (see attached to the post) with TWO caveats:
    • Step 67, there was no "BC_DIGITAL_V" in my FSW_PSW.MAN
    • In Step 77, the "SG_CODIEREN" did not return a positive result and failed to write the code
    • I selected the F2 job again and instead chose: "SG_CODIEREN_OHNE_FG"
    • On execution, the code then wrote successfully. (Confirmed in the main window with "Job Ended")
    • Moving on Step 81, I could not really understand what was being said and I did see what it was relating to.
I have done no further work today, as my battery was getting low and I could hear the vehicle battery becoming drained, especially following a dashboard warning! I have a power supply and will continue tomorrow.
My questions are:
1. Does it sound like I have managed to code the ECU?
2. Are there any files I can provide to prove it, (I have not amended any files from the appropriate directories)
3. What else can I and should I check when I next connect into the vehicle?
Any advice, previous experience from you experts and insights will be hugely appreciated - happy to also pay someone who knows what to look for!
All the best,
David
File Type: pdf
Old Apr 19, 2024 | 12:35 PM
athemiya's Avatar
athemiya
Attached my Tracee File as well
Find attached here -
File Type: txt
Old Apr 26, 2024 | 03:07 AM
athemiya's Avatar
athemiya
Anyone??
RichBRG
May 23, 2022 04:53 PM
tway
R60/R61 Stock Problems/Issues
Jan 2, 2018 08:12 AM
zeusboy
Jul 26, 2011 06:38 AM
agile_moments
Oct 20, 2005 06:48 PM
