Electrical Wiring schematic for 2008 R55 Speedometer
Old Jun 5, 2023 | 07:55 AM
copekyle's Avatar
copekyle
Hello-
I'm looking for the wiring schematic for the 2008 R55 speedometer. Specifically the 6 pin connector that goes into the speedometer.
What is this called in the official documentation? I see instrument cluster and auxiliary instrument cluster in the only diagram I can find (from a 2006 and so it could be different). Essentially, I'm trying to figure out what each signal should be because I got a replacement speedometer and the fuel gauge and all the warning lights don't work. I'm not sure if they are a simple high/low signal or some sort of can bus or if they even trigger from that connector or if it's in the ribbon connector between the cd player and the speedometer.
Old May 13, 2024 | 05:32 AM
Swr1626's Avatar
Swr1626
Originally Posted by copekyle
Hello-
Did you manage too fix this issue as I'm having the exact same problem
thanks
MiniMe_
Aug 16, 2020 11:08 AM
digidoc1010
Nov 22, 2017 09:49 AM
Spicy-Mayo
Sep 19, 2016 01:16 PM
JohnnyZenith
Jun 14, 2016 10:52 AM
razorfish228
Electrical
Jan 23, 2011 05:20 PM
