Electrical NEWB Question regarding connecting OBD-II Readers
Old Apr 28, 2018 | 09:31 AM
derrickyoung's Avatar
derrickyoung
Probably the most basic question but I am 4 days into a 2010 Cooper Clubman and 2 days into OBD-II Scanners. Quick search did not yeild what I was looking for.
I have a DKAN cable and OBDLINK LX BT adapter. When I connect the OBDLINK BT adapter and start the car I can connect to it no problem. If I hit the start/stop button so car is off but accessories are powered up non of the apps will connect to the sensor. However there are some functions in the various apps I have tried (clearing a code) that say car should not be running but powered on.
I have tried just inserting FOB into dash and then connecting but does not seem to work. I have tried running the car then stopping and does not work. I have tried using the USB cable instead of BT adapter same result.
I have the Carly adapter coming today via Amazon and wondering if I will see same behavior and is it something I am doing wrong
Old Apr 28, 2018 | 10:41 AM
Whine not Walnuts's Avatar
Whine not Walnuts
Going to move you to the Gen2 area as our Gen1 cars don't have an ECU only an Abacus.
Old Apr 28, 2018 | 12:22 PM
derrickyoung
Well that explains why all the Stickies I was reading before were missing
Old Apr 28, 2018 | 02:28 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
If you hit the start/stop button so the engine is not running but the accessories are on, this is not the correct mode. You want to put the key in and hit the start/stop button so that the engine doesn’t start but the car is in “Run” mode.
Old Apr 29, 2018 | 02:36 AM
derrickyoung
Thank you, that did it for me and managed to clear the code
cstrumol
Nov 2, 2017 04:56 PM
Eleo
Jul 5, 2013 02:34 PM
Keep Up
Cooper (non S)
19
Apr 2, 2008 01:34 AM
UKXPAT
Sep 28, 2006 03:26 PM
sndwave
Jan 8, 2004 08:28 AM
