Wireless OBD Readers and Apps
Old Oct 16, 2017 | 06:41 AM
cstrumol's Avatar
cstrumol
Looking for a wireless (Bluetooth or WI-fi) OBD reader to use for some data logging and might convert/overlay the center speed-o with an old tablet as a gauge cluster. What scanner are you guys using and what apps? I've seen DashCommand and Torque as the most popular. Thanks
Old Oct 16, 2017 | 07:34 AM
AoxoMoxoA's Avatar
AoxoMoxoA
I'm using DashCommand for the iPhone (6s) with a Vgate iCar 2 OBDII scan/reader in wi-fi mode. Very happy with this setup.
Old Oct 16, 2017 | 08:29 AM
csllover's Avatar
csllover
+1, seems accurate.
Old Oct 16, 2017 | 09:21 AM
3lusive's Avatar
3lusive
Android here - I use the Veepeak bluetooth obd2 adapter with Torque Pro. Works perfectly.
Old Oct 16, 2017 | 01:07 PM
cstrumol's Avatar
cstrumol
Awesome, seems like you can't go wrong with:
Android - Bluetooth - Torque or
iOS - Wi-FI (although I see some BLE4.0 options that work) - DashCommand
Old Oct 26, 2017 | 05:22 PM
Bnourai's Avatar
Bnourai
So wifi mode but how will it work if you don't have wifi as you drive? Sorry for my stupidity.
Old Oct 26, 2017 | 09:41 PM
squawSkiBum's Avatar
squawSkiBum
Moderator
I bought an OBD2 - BT adapter from Newegg online for $17 a few years back, $5 for the Torque app on Android, and it has paid for itself many many times over and I have used it on multiple cars.
If you have one of those overpriced phones from that fruit company you need an OBD2 - wifi adapter, the phone wifi direct connects to the adapter.
Old Oct 27, 2017 | 06:54 AM
Bnourai's Avatar
Bnourai
I am looking at a Veepeak that said wifi and Bluetooth for ios.yes I do have an iPhone 7+.
Will it work or I still need adapter.
Thx
Old Oct 27, 2017 | 07:16 AM
AoxoMoxoA's Avatar
AoxoMoxoA
The Vgate scan tool I referred to in my earlier post creates it's own short-range wi-fi network that you log into with your phone to get data.
No additional wi-fi is needed, so as long as you're within 10-meters of the Vgate device (plugged into your OBDII socket), you'll get uninterrupted data from your engine.
Old Oct 27, 2017 | 07:24 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The adapter broadcasts a low power wifi network, which your phone connects to. Once connected to that adapter network, you open the app and you can see the vehicle information.
Old Oct 27, 2017 | 11:50 AM
StephenM's Avatar
StephenM
I have heard that DashCommand hasn't been updated in some time, and the OBD-II supported features for MINI on the website was last updated 2009. Will I get full functionality on an F56?
Sorry for the thread hijack!
Old Oct 27, 2017 | 12:36 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Dash command seems to work good for viewing on-the-fly data, and some data logging. Not sure it collects ALL PID data during logging, but I've only used it a few times and it had what I wanted.
For any diagnostics, I use the Carly app.
Old Oct 27, 2017 | 02:12 PM
Bnourai's Avatar
Bnourai
so i ordered the Veepeak wifi, now need a good recommendation for the app. the fusion seems to be good but like to know better from the community. i am on stage 2 manic and like to monitor all goods. right now i have a scangage 2.
Old Oct 30, 2017 | 06:34 AM
Derek86's Avatar
Derek86
I put this setup together last week and I'm pleased with it so far.
Old Oct 30, 2017 | 09:36 AM
Bnourai's Avatar
Bnourai
Obd2
HI,Do you also get air intake temp?
Old Oct 30, 2017 | 09:45 AM
Bnourai's Avatar
Bnourai
i got the obd Fusion its ok but cant find any info on my air intake temp...anyone on this app can you help please?
thx
Ben
Old Oct 30, 2017 | 10:25 AM
Derek86's Avatar
Derek86
Yes, although I haven't done my research to know where the measurement is being taken in the intake track.
I was not able to get Oil Temp to work properly, not sure if the car is even set up to read that. I'm still working on it.
Old Oct 30, 2017 | 03:18 PM
Bnourai's Avatar
Bnourai
I just did the dash command, like it better it has them all. i have not setup or seen oil temp. i dont think our's support that.
Ben
Old Nov 2, 2017 | 12:04 PM
Bnourai's Avatar
Bnourai
I could not find an answer to this question on Google.
Will the wifi generated by the device be sufficient to operate a ipad mini in the car for other purposes?
Thx
Old Nov 2, 2017 | 12:11 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Thx
What other purposes? The WIFI ODB dongle only allows connection to the car diagnostic port.
Old Nov 2, 2017 | 12:20 PM
AoxoMoxoA's Avatar
AoxoMoxoA
If by "other purposes" you mean receiving access to the internet, then no, it's only for communication between the OBDll dongle and the software.
Old Nov 2, 2017 | 01:01 PM
Bnourai's Avatar
Bnourai
Yes that's what is what I was thinking...
Thank you
Ben
Old Nov 2, 2017 | 01:14 PM
H_C's Avatar
H_C
If you're invested in the iOS ecosystem, get a LELink ODB-II adapter (http://www.outdoor-apps.com).
I currently use both OBD Fusion (for gauges and data logging) and EngineLink (to diagnose issues).
This OBD-II adapter uses Bluetooth LE. With this system, you don't need to manually pair it to your iPhone. Just open the OBD-II app and it'll connect automatically. Also, Bluetooth LE allows for you to stay paired to your car's radio while being connected to the device (you can stream music/make calls while using the OBD-II adapter).
Old Nov 2, 2017 | 04:56 PM
Bnourai's Avatar
Bnourai
Wow very nice.
What I have in mind is to use my iPad mini in the car, I have unlimited data so I can use many features and also the obd2 and my dash command.
For multi use your suggestion is perfect.
Thank you
Ben
