Electrical How Many Accessories Can a MINI Run?
Old Apr 27, 2018 | 05:33 PM
Kalibdor's Avatar
Kalibdor
So this question may be just as much general electric/automotive as it is MINI specific but I wanted to see if anyone here had any first person experience as I know very little about electrical.
I'm wondering how many devices you can have hardwired (either spliced into 12v switched power or hardwired via add-a-fuse) without issues. I'm looking to have radar, laser jammers, dashcam, as well as digital boost gauge all hardwired, with a phone plugged into the usb for power, and a gps using the cigarette lighter. All devices would be running simultaneously for extended periods of time (maybe 6-8hrs a day with breaks here and there).
If it's going to be a problem, is there such a thing as a secondary accessory power setup? I've seen guys with extensive CB setups (in MINIs) that I assume draw a good amount of power, running in combination with other accessories using the cigarette lighter with a splitter, so I figure it should be doable, but I'm wondering if there's a line.
Thanks for any and all advice.
Old Apr 27, 2018 | 06:20 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
One hefty stereo power amp or subwoofer amp draws a lot more power than what you are talking about. I don't see an issue, especially with the car running and charging.
*not an electrician. just make sure everything is properly fused and wired.
Old Apr 27, 2018 | 07:31 PM
Fly'n Brick's Avatar
Fly'n Brick
It's simple Ohm's law. If you've got a 10 amp fuse you need to total the current demands of each item you'll put on that circuit and quit when it totals 10. The power equation is power = voltage times current. Therefore, current (amperage) equals power divided by voltage. Most devices come with some of that information somewhere on a sticker or the box. When all those doodads total 10 Amps or whatever fuse you've got, it's time to find another circuit.
Old Apr 27, 2018 | 07:36 PM
Kalibdor's Avatar
Kalibdor
Good explanation, thank you.
PlanetKid
R55 :: Clubman Talk (2008+)
29
Jan 10, 2012 01:20 PM
customcoops
Jun 21, 2010 03:14 PM
navyhuey
May 4, 2009 05:05 PM
SpiderX
20
Nov 12, 2004 06:45 AM
