Electrical JB4 ODB routing
Old Jun 6, 2016 | 06:16 PM
jeffster06's Avatar
jeffster06
JB4 ODB routing
I am trying to install my JB4, The instructions say to just push the grommet with the clutch line aside and run the OBD plug through there (there picture on the install is of the opposite side of the brake booster though). My question is it doesnt seem like enough space to fit the connector through (small one not the OBD) how has everyone else ran the OBD wire?
Old Jun 6, 2016 | 07:20 PM
jeffster06's Avatar
jeffster06
Nevermind I got it. Small screwdriver helps to shift the grommet, the connector was still hard to push through but with a little effort it will go.
Old Jun 13, 2016 | 09:43 AM
MarcoPolo's Avatar
MarcoPolo
so is it fully installed? when do you plan on pulling up some logs? i want to start comparing logs.
Old Jun 13, 2016 | 11:51 AM
jeffster06's Avatar
jeffster06
It is fully installed, unfortunately I need to order the usb cable to start pulling logs. I also need to figure out what I am going to use to gather logs.
Old Jun 16, 2016 | 04:43 PM
GregoryK's Avatar
GregoryK
Ran my cable through the same grommet I used for my gauges. To right corner of the firewall. Should look really clean once I've installed the JB4. I'm filled up with 93 octane and am going to run map 2 right out of the box!
I can't wait for the weekend.
Old Jun 16, 2016 | 05:01 PM
jeffster06's Avatar
jeffster06
Do you have a picture of the grommet? I couldn't seem to find anything to run through except the clutch line one.
I ran map 2 right at the beginning too, figured why not lol.
Old Jun 16, 2016 | 05:03 PM
MarcoPolo's Avatar
MarcoPolo
i believe that's the grommet we're all talking about.
did you log your MAP2 run?
Log it!!
Old Jun 16, 2016 | 05:46 PM
jeffster06's Avatar
jeffster06
Marco it's gonna be a little bit before I start logging maps, I need to order the cable and then figure out what I'm gonna log on.
solomio
Oct 19, 2018 11:12 AM
Mini-Chedrz
Mar 30, 2016 07:40 AM
iclancy82
Mar 25, 2016 08:37 AM
pj.rodriguez
Cooper (non S)
Mar 22, 2016 10:47 AM
MiniSkoon
Mar 14, 2016 12:45 PM
