Electrical Accessory Gauge Wiring
Old Nov 12, 2015 | 07:32 AM
papawhiskey's Avatar
papawhiskey
So I'm just about ready to hook up the discreet oil temp & oil pres gauges I've installed and I have a couple of questions to see if I can get some input on. I'm going to need power and ground which I figured I'd tap off the fuse block. The sensors are fairly straight forward too. It's the lighting that concerns me and the CANBUS that these cars operate with.
Can I tap into one of the dash or center pod wires that provide switched/dimmed lighting without the car throwing a code?
Or is there a tap on the fuse block that's switched/dimmed lighting perhaps to use?
Old Dec 20, 2015 | 05:37 PM
MarcoPolo's Avatar
MarcoPolo
hey, what did you end up tapping into? i'm putting a boost gauge next week...did you tap close to the driver side or did you extend to the fuse box and use a fuse tap?
Old Dec 21, 2015 | 08:10 AM
papawhiskey
Went over to the fuse box. Not as easy but the better choice in my opinion.
Old Dec 21, 2015 | 08:21 AM
MarcoPolo's Avatar
MarcoPolo
gotcha. thanks. what did you tap in to? or did you have/find a wiring diagram?
i haven't event looked under there yet but want to be prepared when i do.
Old Apr 19, 2016 | 10:37 AM
GregoryK's Avatar
GregoryK
Papa. Did you manage to find a dimming circuit in the fuse box or just an on off. I now have the time to install my gauges and it would be nice if they could dim.
Old Sep 16, 2016 | 10:48 AM
Loccusst's Avatar
Loccusst
Is it possible to tap into the light switch itself?
Old Sep 16, 2016 | 11:02 AM
GregoryK's Avatar
GregoryK
There is no light switch...no 12 volt circuit. It is all software based. That is why the dimmer switch panel to the left of the steering wheel only has 3 wires going to it. Mine has 2 sets of light switches a 4 position switch for the main headlamps and the dimmer....3 wires and a massive circuit board! Not for the faint of heart....
Old Sep 20, 2016 | 08:08 AM
Loccusst's Avatar
Loccusst
Hmm. I wonder if you can piggy back of off an output somewhere other than the fuse block.
Old Oct 3, 2016 | 09:09 AM
GregoryK's Avatar
GregoryK
You could patch into the board below the steering wheel on the left. The one with the dimmer on it. If you have the fog light switch it is dimmed I believe.
Old Feb 8, 2017 | 04:13 AM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Just received my boost gauge and will install it in a few days...
Does anyone knows if the fog lights switch is dimmed and ok to tap in?
Or should I extend to the fusebox, fuse #52 seems to be the one to choose from what I've read so far?
Thanks for any help!
I'll take pictures of the whole install and do a "how-to" for future reference on NAM! 🤗
Old Mar 19, 2017 | 08:58 AM
leozip's Avatar
leozip
need help with this as well for boost gauge install. Anyone?
Old Mar 20, 2017 | 09:03 AM
toyopet's Avatar
toyopet
I connected constant power and ignition to the fuse box. For constant power, I used a fuse tap in slot #87. For ignition I used a fuse tap in slot #50. For my gauge light, I connected to ignition because the LED would flicker if I connected to the instrument panel cluster. Therefore, my gauge light is always on.
Old Mar 20, 2017 | 06:06 PM
leozip's Avatar
leozip
will try that route, thanks.
RHcoopers
Mar 29, 2016 08:42 AM
papawhiskey
Nov 24, 2015 08:02 AM
Doc Pain
Oct 28, 2015 07:09 PM
schr5530
Oct 7, 2015 12:49 PM
got_mini?
Oct 5, 2015 02:53 AM
