Drivetrain Oil Port?
Old Oct 5, 2015 | 06:43 AM
papawhiskey's Avatar
papawhiskey
Oil Port?
I've just installed oil pressure and oil temperature gauges using CravenSpeed's new gauge mount for the F5X Minis. Now I need to connect the sending units to the engine and I can't seem to find a port to engine oil anywhere. The most logical spot was by the oil filter housing, but I could find a plug or port. If anyone has seen a B4X or even a B38 engine up close or out of a car I'd appreciate and info you might have.
Old Nov 17, 2015 | 06:25 PM
GregoryK's Avatar
GregoryK
Check this drawing - it's the 3 cylinder but I'm sure the sensor is in the same place. The oil pressure sensor part number is the same as the JCW. Clearly this is not a great position to get to - wish we could tap into the wiring harness for the MINI gauge pod.
http://parts.miniofkennesaw.com/show...oduct=10197503
Old Nov 18, 2015 | 02:06 PM
GregoryK's Avatar
GregoryK
Papa- Just our of interest Autometer recommend that you go with a sandwich oil filter adapter with 1 or 2 x 1/8"npt threads. They say that is the best way. Certainly easy to get to. Thoughts?
- forget this of course MINI's have paper filters! The Oil sensor tread is M12 x 1.5 but that would have to adapt to a 1/8" npt....tough.
Old Nov 19, 2015 | 04:40 AM
papawhiskey
I was going to say - no sandwich adapter, not even if you had one of my Spin-on Oil Filter Adapters that could use a sandwich adapter, as there just isn't enough room before you hit the lower radiator support (I've tried).
If you're certain that the oil port is M12 X 1.5 then I can work from there to make an adapter for one or two additional ports (2,3 total) so we can add extra sensors.
Old Nov 19, 2015 | 04:53 AM
GregoryK's Avatar
GregoryK
I would want to get a MINI oil pressure sensor to confirm. I read that size is pretty standard on the new BMW engines.
Old Nov 19, 2015 | 05:58 AM
papawhiskey
When compared to the 1/8 NPT usually seen on the sensors an M12 thread is somewhat large (almost 1/2" OD) so verification is in order before I can proceed. It shouldn't take long to gen up an adapter once I get in there to see where the clearance(s) might be.
I wouldn't buy a sensor just dig down there and pull the one on the car and measure. Whoever gets there first has to spill the beans!
Old Nov 19, 2015 | 08:27 AM
vetsvette's Avatar
vetsvette
Moderator
PW. What is this Spin-on Oil Filter Adapter of which you speak?
Old Nov 19, 2015 | 10:09 AM
papawhiskey
I designed and developed an adapter to convert the new Minis (F-series) from the paper element filter to a standard spin-on oil filter. I tried to offer it here but the sponsors didn't like it and took down my post (thyy may do it with this one too). Anyway I'm on ebay:
http://www.ebay.com/sch/i.html?_odkw...6+oil&_sacat=0
It uses spin on filters that are available about everywhere, takes about ten minutes to install and is completely reversible. If you like the idea - buy one - I'd appreciate it! In fact I'm almost done with a remote oil filter set up for the R series cars so you don't have to futz with the radiator overflow tank to change your oil filter - tell your friends.
PapaWhiskey
Old Nov 24, 2015 | 08:02 AM
vetsvette's Avatar
vetsvette
Moderator
PapaWhiskey
Thank you Sir. I will check it out.
JCW Clubman 2010
Oct 1, 2015 01:57 PM
IDOXLR8
Sep 24, 2015 05:05 AM
co0p3r
Sep 23, 2015 08:25 PM
pkrysR56
Sep 19, 2015 07:58 AM
mbatech
Sep 10, 2015 03:40 PM
