Electrical Scangauge 2 oil pressure
Old Mar 24, 2014 | 07:25 PM
cw40342's Avatar
cw40342
Ok I know this has been on here several times but I'm trying to figure out this scan gauge deal.
I have a 2002 Mini Cooper S is there a way to get the scangauge to read the oil pressure on my car? If this gauge reads what I've read on here then do I even need any other gauges?
Old Mar 24, 2014 | 08:15 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Sorry it can't be done on the R53.
Old Mar 25, 2014 | 04:18 AM
cw40342's Avatar
cw40342
I know you have electronic and mechanical gauges I'm assuming you can do a electronic gauge. I have read about adapters to the oil pressure sensor?? And do you have all the things needed to do that set up?
Is there really any benefit to using the scangauge on a R53?
Old Mar 25, 2014 | 04:44 AM
RA082324's Avatar
RA082324
the benefit would be all the other gauges, for instance boost, intake air temp, volts, water temp, etc.
also anytime the cel comes on, you can turn the car off, scan, note the code, clear it, and assuming nothing is seriously wrong, continue on without ever having to leave the car.
im just saying, i have one, and its unfortunate that it doesnt provide oil temp/pressure, but the other functions have served me well.
i have it mounted to the bottom of the climate controls, above the cup holders with some strong velcro.
Old Mar 25, 2014 | 06:03 AM
cw40342's Avatar
cw40342
Originally Posted by jown.iv
the benefit would be all the other gauges, for instance boost, intake air temp, volts, water temp, etc. also anytime the cel comes on, you can turn the car off, scan, note the code, clear it, and assuming nothing is seriously wrong, continue on without ever having to leave the car. im just saying, i have one, and its unfortunate that it doesnt provide oil temp/pressure, but the other functions have served me well. i have it mounted to the bottom of the climate controls, above the cup holders with some strong velcro.
Where would be the best place to get one? And it does show boost? That would be awesome! Does it show the readings or is it all in codes and whatnot?
Old Mar 25, 2014 | 06:44 AM
RA082324's Avatar
RA082324
i believe i ordered mine from either way motor works, or amazon. it was over a year ago, so i cant remember haha.
it does show boost. and it does shiw the readings in "real time". i say that in quotes because, while it does deliver a constant reading, there is about 1 second of lag time since it is a digital gauge, rather than the analog kind that would require you to tap into an actual boost line.
i believe it has its own website as well where all the features may be more detailed for you. some basic points though, it displays 4 different gauges at once, scans/clears check engine lights, can log gas mileage if you are into that sort of thing, etc.
i just like the peace of mind it gives me. my car is pretty heavily modded, so its nice to be able to know whats going on. and if you ever get rid of the car, the scangauge2 can be plugged into any obd2 vehicle.
Old Mar 25, 2014 | 11:50 AM
cw40342's Avatar
cw40342
Sweet! I'll check it out although might be a little while just had the control arm bushing sway bar steering rack inner outter tie rods and ball joints. All bushing poly urethane from madness motor works. So so happy
Old Mar 25, 2014 | 12:01 PM
Javskies's Avatar
Javskies
do you have a smart phone? just get a bluetooth obd2 adapter and download the app torque and it works just the same as a scan gauge. it makes my life so much easier lol
Old Mar 25, 2014 | 02:02 PM
cw40342's Avatar
cw40342
I have the iPhone 5s. If it's in the App Store I'll check it out sounds pretty sweet to me
Old Mar 25, 2014 | 02:05 PM
bavmotors's Avatar
bavmotors
[QUOTE="cw40342;3902176"] I have the iPhone 5s. If it's in the App Store I'll check it out sounds pretty sweet to me [/QUOTEno torque on the iphone. Dash command for us on iOS, I use it with an elm 327.
Old Mar 25, 2014 | 05:38 PM
Javskies's Avatar
Javskies
i was trying to remember so hard what the iPhone variant was lol. thanks! i got my adapter for 13 bucks and it came for in the us so shipping was a few days
Old Mar 25, 2014 | 05:43 PM
cw40342's Avatar
cw40342
Do you have a link for that adapter
Old Mar 25, 2014 | 05:52 PM
bavmotors's Avatar
bavmotors
Got mine off amazon, beware of the fakes!
Javskies's Avatar
Javskies
here you go http://www.ebay.com/itm/Mini-ELM327-Interface-V1-5-Bluetooth-OBD-II-OBD2-Auto-Car-Diagnostic-Scan-Tool-/151246009662?pt=Motors_Automotive_Tools&hash=item2336f6f53e&vxp=mtr
Old Mar 25, 2014 | 05:53 PM
RJT's Avatar
RJT
Look for the Simvalley OBD ii Vgate WiFi...got it off Amazon and shipped in three day..works like a charm with DashCommand and the IPhone 5s..mated to a CravinSpeed smartphone holder
Old Mar 25, 2014 | 07:04 PM
WayMotorWorks
Vendor
We keep them in stock
http://www.waymotorworks.com/scangauge-ii.html
For other gauges we can fix you up with a nice Craven setup, they fit great and work great.
Old Mar 26, 2014 | 06:07 AM
cw40342's Avatar
cw40342
Man that's a sweet set up what reads the boost? Manifold pressure?
Old Mar 26, 2014 | 06:10 AM
cw40342's Avatar
cw40342
We keep them in stock http://www.waymotorworks.com/scangauge-ii.html For other gauges we can fix you up with a nice Craven setup, they fit great and work great.
I don't know if I'm going to go with the scangauge or the Bluetooth now
However I absolutely need a gauge for oil pressure do you guys sell the mounts that attach to the tach?
Old Mar 26, 2014 | 12:13 PM
bavmotors's Avatar
bavmotors
Don't get a Bluetooth if u have an iphone though, the wifi version is compatible only.
Old Mar 26, 2014 | 01:06 PM
cw40342's Avatar
cw40342
Well that sucks!
Old Mar 26, 2014 | 05:54 PM
cw40342's Avatar
cw40342
Question two
Where can I get a gauge to match the factory ones WITHOUT spending a fortune I've seen some kits $599.00!!!!!!!
Old Mar 27, 2014 | 09:03 PM
Gambedegallina's Avatar
Gambedegallina
No oil pressure through OBDII. Need to install oil pressure sensor and gauge. Craven/Marshall is great match to factory, matches interior, but install is work. Many threads on nam.
Kimolaoha
Jul 5, 2023 01:04 PM
TREX
Nov 2, 2019 07:31 PM
Indimanic
Aug 19, 2015 11:08 AM
Emnotek
Aug 13, 2015 05:47 PM
