Electrical LED Flasher relay for R56?!?!?!
Old Feb 27, 2014 | 10:14 PM
topdog502's Avatar
topdog502
I'm doing a LED conversion on all lights but I need a LED compatible flasher relay but can't I find one. Anyone know where I can get one?
Old Feb 28, 2014 | 03:38 AM
r34king's Avatar
r34king
Use can bus bulbs or wire in resistors if you are making your own. I got the spec d tails on my r53 that cause hyperflashing. One stop at radio shack for a pair of resistors fixed that
Old Feb 28, 2014 | 08:06 AM
topdog502's Avatar
topdog502
How do you know what resistors to get?
Old Feb 28, 2014 | 08:15 AM
ZippyNH's Avatar
ZippyNH
Or buy a led bulb with the resistor built in...pretty common...combined led/resistor should have the same ohm (resistance) as the bulb...I suggest you DO NOT CHOP UP YOUR WIRING...
Old Feb 28, 2014 | 08:18 AM
topdog502's Avatar
topdog502
Yea I really didn't want to do that. I'll have to look around.
Old Feb 28, 2014 | 09:08 AM
rkw's Avatar
rkw
That doesn't apply to MINI's. MINI and many newer cars don't use flasher relays. The turn signals are directly connected to the computer, which blinks them using software. Many other cars (especially older) use a flasher relay to flash the turn signals, and in that case you can replace the relay with a version designed for LED.
Old Feb 28, 2014 | 09:16 AM
r34king's Avatar
r34king
If you are just swapping bulbs get the "canbus" bulbs. Will trick the jbe to think the bulb isn't blown
Old Mar 6, 2014 | 11:01 AM
VoodooJC's Avatar
VoodooJC
I got these and they work perfectly for my brake and turn signals. Direct swap. No bulb out warnings.
AvianMan
17
May 17, 2019 07:25 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
WayMotorWorks
Aug 25, 2015 10:01 PM
gknorr
Aug 24, 2015 06:39 PM
