Electrical The Foot Well Module: functions, problems, solutions?
Old Oct 14, 2016 | 06:49 AM
  #151
MiniToBe's Avatar
MiniToBe
I suppose you checked the actual bulbs? did you see any water intrusion on the FRM connectors?
I'll check for you when i get home if i can find something.
Old Oct 14, 2016 | 08:48 AM
  #152
Tim McCreary's Avatar
Tim McCreary
No water damage, no power at connector to light socket. Good ground.
Drivers side reverse and high mount stop light wont light. No bulb out codes. Bulbs good.
Thanks,
Tim
Old Nov 16, 2016 | 06:18 PM
  #153
Hokie94's Avatar
Hokie94
Same issue here as everyone else
First post on the board...
Owner of a 2012 Mini Cooper S Hatchback
All started when trying to repair a bad thermostat sensor (which still needs to be fixed).
I disconnected the battery for the sensor repair and after reconnecting the battery the red lift light appeared. No control of windows, headlights, hazard, license plate lights interior mood lighting.
Ive contacted Jims Import to see if they have the part.
Any one willing to check my FRM to see if its dead or reprogram it? Willing to pay (and throw in some craft brews from my hometown).
Old Nov 16, 2016 | 06:30 PM
  #154
MiniToBe's Avatar
MiniToBe
Welcome aboard and sorry for the hickup. There are few things you can to at least get back on the road. Try to match your FRM part number with ones on ebay or car-part.com (preferably). If you do not have programming tools, either invest in them (may cost anywhere from 50 to couple hundred) or hopefully NAM member near you can help. Im in philly PA.
Old Nov 24, 2016 | 07:16 AM
  #155
aviaator's Avatar
aviaator
I shouldn't have read this thread...
From all the posts here I'm gathering that the simple task of disconnecting and reconnecting the battery can fry the FRM?
That's INSANE!
Old Nov 24, 2016 | 07:19 AM
  #156
MiniToBe's Avatar
MiniToBe
Not always. I do that numerous times and nothing happens to the module. There might be a some sort of a free replacement from dealer. Check the threads here as some was able to get it gone from the dealer. Or you can buy a used one with matching options or part number. It will work.
Old Nov 24, 2016 | 07:25 AM
  #157
miniuy's Avatar
miniuy
That's INSANE!
It is possible but it is not usual. In fact, it would be strange.
It is more likely to fry the FRM if you are working with the car wiring without disconnecting the battery.
Or a wrong electrical task that will fry the FRM when reconnecting the battery.
Old Dec 19, 2016 | 05:40 AM
  #158
Heaven's Avatar
Heaven
Alternator
My alternator went while I was driving, battery was drained. Would this likely kill the FRM permanently?
Old Dec 19, 2016 | 05:46 AM
  #159
miniuy's Avatar
miniuy
It should not.
Did you replace your alternator and now your FRM is dead?
Old Dec 19, 2016 | 05:51 AM
  #160
MiniToBe's Avatar
MiniToBe
Signs of dead FRM include inoperable windows and lights. do you have these signs?
Old Dec 19, 2016 | 09:48 AM
  #161
Heaven's Avatar
Heaven
Yes, I knew it was on its was out because the battery light came on. I only made it halfway to the garage when the car stopped running. The alternator was replaced but my garage (which is pretty good) can't get that unit to come on at all. They sadly are sending me to the dealership$$$
Old Dec 19, 2016 | 09:51 AM
  #162
MiniToBe's Avatar
MiniToBe
What unit are you referring to?
Old Dec 19, 2016 | 09:57 AM
  #163
Heaven's Avatar
Heaven
The driver's side foot well module. After the car was delivered on the tow truck, I locked it up but the window got open somehow during that night and there was several inches of snow. My mechanic thinks it got wet (although they have had it apart and it doesn't "look" wet. I was wondering if the alternator going could have shorted it. Since I think I was the last one in the car an I know the window was up, it just seems like too big of a coincidence that the Module gor wet then shorted, instead of being hinky and rolling down the window first.
Old Dec 19, 2016 | 10:00 AM
  #164
Heaven's Avatar
Heaven
Car is going on 150K, 2010 Clubman S
  #165
MiniToBe's Avatar
MiniToBe
As we speak, do the windows roll up and down?
Old Dec 19, 2016 | 10:24 AM
  #166
Heaven's Avatar
Heaven
I don't know, it is still at the shop. The only thing I heard was that it took him awhile to get the window to go up. He said they can't communicate with the module at all, it's like it isn't there. I asked if it was driveable (to get it to mini) but have not heard back yet.
Old Dec 19, 2016 | 10:31 AM
  #167
MiniToBe's Avatar
MiniToBe
if he got the window up. I think the module is still alive. Sometimes you have to roll the window all the way down to be able to roll it up. Otherwose it will be moving up 1mm at a time.
When you hear back from them, ask them of the lights turn on and off!
Old Dec 19, 2016 | 10:41 AM
  #168
miniuy's Avatar
miniuy
+1
+1
As MiniToBe said, you can detect a dead FRM by:
- No power to windows
- No turn signals
- No high beams, fog lights
- Low beams always on
Check this on the car
Old Dec 19, 2016 | 10:42 AM
  #169
Heaven's Avatar
Heaven
By the sound of it I wouldn't be surprised if it was going up 1mm at a time. . . but thanks, I will find out about "what's out"
Old Feb 9, 2017 | 09:18 PM
  #170
sheardc's Avatar
sheardc
Just joining this thread now. Have a 2010 Mini Clubman. Went to take a ride on Tuesday and got all kinds of odd things occurring in vehicle:
-windows only moving 1" up or down, Window alert on small tach screen
-Headlight warning alert on small tach screen, headlights worked fine
-TPMS warning yellow LED on
-Brake fault yellow LED on, brakes worked and temp after short ride was of by touch, Emergency brake red LED worked normally
It had rained the day before so I thought a short drive would clear the issue. The Emergency flashers started working without activating button on top of dash!! The finally switched to a "6 flashes then off for 1 min" cycle.
Stopped the car for about 2 hours and came back for another short ride. This time
-windows still had same issue and warning display on tach screen
-Headlight warning display on tach screen
then all the errors stopped and the dashboard lights kept flickering between night and day mode (like switching the left hand stalk rotating switch)!!
Called my local garage and explained situation. They called me back about 4 hours later and said "the FRM was bad, water had gotten into it and a component had fried"!! They want $1,100 to install new FRM and reload code. YIKES.
I plan on stopping over to shop to see location and damaged FRM. Sounds like there could be a leak somewhere.
Read most of this article. Do not want to tackle this as I do not have the tools to fix it.
Why is the FRM not made to be more waterproof!! Seems like a bad design.
Old Feb 10, 2017 | 05:48 AM
  #171
MiniToBe's Avatar
MiniToBe
Sheardc, welcome aboard. as discussed earlier in the thread, a dead FRM will not be able to let you control the windows at all and the headlights will remain on all the time when you turn on/start the car.
It is proven (and I have done it several times) that you can buy a used FRM with matching part numbers or matching options. check ebay and my favorite site car-part.com
instead of wasting 1100 to the shop, invest in programming SW like WinKfp and NCSexpert and get the K+Dcan cable. these will run you less than 100. With remote access anyone here on the board can help either for free or a small fee
as for it being a bad design, I think it is the location that is bad not the design. Everything has a life expectancy and eventually will die/break/malfunction no matter how it is made. The good news, it is replaceable
Old Feb 10, 2017 | 06:16 AM
  #172
miniuy's Avatar
miniuy
+1 on these directions if you can't afford 1100 on the shop
Additionally, you need to fix the water issue before replacing the FRM module.
With the software and a compatible FRM module in your hands, the swap takes no more than 15 minutes.
Old Feb 10, 2017 | 07:58 AM
  #173
rsplodge's Avatar
rsplodge
I'm not supposed to say any of this as I signed a confidentiality agreement (but who cares the car is sold now!): I wrote a letter to my dealer and threatened to go public on Social Media about the issue and I also contacted BMW North America to report the problem and to complain. They finally covered the whole repair. In my case though there was a mini fire down in the FRM and you could see the scorched components (I removed the FRM myself to look). Still the location is absolutely stupid and that's why so many people are having problems. Furthermore water can get in via the sunroof drains or other means. Really, really, really poor engineering design.
Old Mar 21, 2017 | 04:58 PM
  #174
Zephyr1's Avatar
Zephyr1
That's INSANE!
That would be insane, and I'm not convinced that dis- and reconnecting the battery can fry the FRM. I think more likely what could happen is that jumping a battery could be a problem if wrong connections or shorts are made, or if the battery is not reconnected properly resulting in a wiggly connection. I have disconnected and reconnected my battery dozens of times, w/o problems. My FRM problems were strictly the connectors (so far, knock on wood) and once sorted, I have not had problems now. It may also be possible that water intrusion coincides with other issues, and then symptoms appear when disconnecting and reconnecting the battery.
Old Mar 24, 2017 | 09:23 PM
  #175
Zephyr1's Avatar
Zephyr1
So in this other thread
https://www.northamericanmotoring.co...w-battery.html
ryansonfire states that:
..had the same problem with my dead battery corrupting the footwell control module. i called the dealership and they have a warranty extension for the footwell control module and they replaced mine for free. call with your vin and make an appointment to get it replaced.
That's the first I've heard of a warranty extension for the FRM. Given how many problems have been reported related to FRM, this is welcome news!
Can anyone else corroborate this, have you heard of this or ad yours exchanged at no cost under a warranty extension?
