Electrical Help from those who have done a heated seat wiring retrofit?
Old Mar 29, 2013 | 04:35 PM
joylove's Avatar
joylove
Hi there
For anyone who has done a retrofit of the wiring harness to enable heated seats, do you recall taking any notes or pictures of the part number for the harness only?
I already have the part number for the retrofit kit. I want the harness part number only!
If you are looking for a thread on whether you can retrofit heated seats to your mini please go to the discussion here.
Cheers!
Old Mar 29, 2013 | 05:23 PM
Hello joylove ,
Do you have the full kit already? Do you need just the harness because you have the center controls? The kit includes the harness , control for mirror control (non power fold mirror ) / heated seats . There is also a fuse and a ground cap wire.
http://www.ecstuning.com/Search/61110145996/ES159515/
Most people check under there seat to see if they have the plugs like article in the link states and our website states. Early MINIs did not come with heated seats pre wired and dependent on the seat type MINI phased in and out heated seats prewired . Best way is to check.
I can search and see if the part is available independently.
Old Mar 29, 2013 | 05:30 PM
joylove's Avatar
joylove
I have the switches already yes, and I'm just after the harness. I've scoured the parts diagrams that are available online to no avail. Thanks for checking!
The same connector is also used for the E46 pre facelift front seats (individual switches in center console), the E83/E53 rear seats and the Rover 75 front seats; but alas no hint of a part number for either that I can find.
Old Apr 1, 2013 | 07:50 AM
Here is the part number just for the harness.
It looks like it does not include the fuse.
Heated seats harness cable only:
http://www.ecstuning.com/Search/61120144084/
Old Apr 1, 2013 | 08:17 AM
joylove's Avatar
joylove
What a hero.
Old Apr 1, 2013 | 08:22 AM
joylove's Avatar
joylove
Emailed sales to add it to my order. Nice one
Old Apr 1, 2013 | 02:41 PM
You are welcome
Old Jan 17, 2014 | 12:08 PM
cbbarrentine's Avatar
cbbarrentine
can someone send me a pic of the heated seat plug on the seat so i can check and see if my seats already have the heating elements in them i have been looking all over the net and have found several different pics of bottoms of seats but none that show which plug is for the heating elements.
Old Jan 17, 2014 | 01:12 PM
joylove's Avatar
joylove
The empty plug in this image is the heater. It's a D system with round pins.
Old Jan 17, 2014 | 04:08 PM
cbbarrentine
Thanks man neither one of my cars have it
Old Feb 3, 2014 | 10:36 PM
joylove's Avatar
joylove
So I managed to score some heated seat mats from an e90. All I need now are two tyco 2.5mm D system 4 pol connectors. Can you find that part number? It looks like the one on the E36 and E36/7 and Rover 75!
http://www.ecstuning.com/BMW-Z3-2.8-...4715/ES177590/
Old Feb 4, 2014 | 05:42 AM
You found you don't have the pre wired seats ? Thanks for the pics , that helps.
I found the coonect 4 pol male size. It looks like the one you need. For your BMW seat heating mat to MINI conversion.
http://www.ecstuning.com/Search/SiteSearch/61131378135/
Old Feb 4, 2014 | 08:23 AM
joylove's Avatar
joylove
EDIT: Do you have the mating half? I nipped to the car, I need the one with male pins.
Edit she DOO!
http://www.ecstuning.com/ES164478/
Awesome ECS again. Now to make up a decent sized order...
Old Feb 4, 2014 | 09:04 AM
Joy; I missed the ... I bow to this part. lol I thought it was great
Here are the parts: Part # 61138352924 Grommet for each terminal. Comes in a pack of 10 now.
http://www.ecstuning.com/Search/SiteSearch/61138352924/ES2722908/
Terminal socket for the white plug. TERMINAL SOCKET 2.5
http://www.ecstuning.com/Search/SiteSearch/61138352926/ES2676461/
I also found the one in black.
http://www.ecstuning.com/Search/SiteSearch/61131378134/ES2602770/
I cannot find the 4 pol male connection that's on that harness. It might take me some time to track it down.
Old Feb 7, 2014 | 10:49 PM
joylove's Avatar
joylove
Well I'm glad I double checked before I ordered, I actually need 3 pol male. Silly me! Do you have the 3 Pol?
The harness side is 61138352304 (universal); 61131378114; 61131378115.
Old Feb 10, 2014 | 08:10 AM
These are hard to track down.
The plug housing in a 3 pol I could not find at this point. Its used for the gong connection on the BMW side which is a full unit.
You could possible use the 4 post above and snap off the one hold tab, still should work. Putting the round to the round side.
http://www.ecstuning.com/Search/SiteSearch/61131378133/
Old Feb 10, 2014 | 08:29 AM
joylove's Avatar
joylove
Dammit.
Does anyone who have heated seats have 10 minutes to take a torch out to the car and the get part numbers from the seat-side of their heated seats connector PLEASE! :D
Old Feb 10, 2014 | 08:43 AM
Found a three pol ( white ) but its on E90 BMW cigar socket: It used on some BMW / MINI cig sockets.
Socket MINI 61346977682 ~15.00
http://www.ecstuning.com/Search/SiteSearch/61346977682/
Hope that helps.
For this plug on your wiring harness ?:
**Edit , I was able to finally find a valid part number off of one of the other sockets not from the E39 but E90 above.
Looks like I was able to find it. It comes in white in a pack of 10. I am glad I found it , but it took me some serious digging on the BMW side of thing I know. You have to know the common parts are they are not all on the ETK shared on BMW and MINI.
Socket Housing part # 61131378113 pack of 10
http://www.ecstuning.com/Search/SiteSearch/61131378113/
Old Feb 10, 2014 | 09:02 AM
joylove's Avatar
joylove
Hmm, that's $60 for two seat connectors. Can you pull a part number from the connector?
Old Feb 10, 2014 | 09:50 AM
See edit above. Found it.
Old Feb 10, 2014 | 10:36 AM
joylove's Avatar
joylove
Incredible! Let me see how many D System pins I have in my stash at home!
Old Feb 10, 2014 | 10:42 AM
Awesome. Let me know what you need.
Old Feb 10, 2014 | 11:38 AM
FranticFreddy's Avatar
FranticFreddy
A quick question....
My MINI came with heated seats. Some time ago the driver seat heater stopped working. The passenger side works fine. Every once in a while I will try the driver side button and the lights blink but it does not stay on and the seat does not get hot.
The other day I was cleaning up inside the cabin and I was spraying electrical contact cleaner inside the AC switches behind the cup holder where someone spilled hot chocolate. I thought I would try it out on the seat heater button and what do you know the lights came on and the seat got hot.
Later on when I tried the switch/button again nothing happened. This leads me to believe that the one switch is bad. Can I replace just the one switch or do I have to replace the all three (Seat Heater and mirror)? And is it possible to replace just the one switch/button?
Old Feb 10, 2014 | 12:51 PM
They come in a full pack, for the Heated Seats / mirror switch version. Then the set for heated seat / mirror switch / fold in mirror version ( which is a little more rare ).
Center Console Heated Seats / Power Mirror Switch ( non power fold in mirrors ) version
Part # 61316918217
http://www.ecstuning.com/Search/SiteSearch/61316918217/
Center Console Heated Seats / Power Mirror Switch / Power Fold Part # 61316918216
http://www.ecstuning.com/Search/SiteSearch/61316918216/
Looks like this: with the extra button for powerfold.
Just make sure you get the right one. Most lily the switch is stuck / broken , if you cleaned it and it still does not work.
Old Feb 11, 2014 | 10:55 AM
joylove's Avatar
joylove
So I've either lost or run out of pins, do you stock them?
And for the BMW D connector/2.5mm series/DIN 72585 from Farnell/RS
Farnell D series
3455737 circular contact D system socket 1.5-2.5mm (regular cable)
3455725 circular contact D system socket 0.5-1mm (thin cable)
3455701 circular contact D system pin 0.5-1mm (thin cable)
3455713 circular contact D system pin 1.5-2mm (regular cable)
1328863 rubber bung D contact system
3455749 rubber bung d system 0.5-1MM2
3455750 rubber bung D sy
3455695 Round socket 4 way
3455671 Round socket 3 way
3455660 Round socket 4 way
3455646 round socket 3 way
3455774 mounting ring round socket
3455786 3455798 3455816 3455830 Backshell round socket
3455762 blanking plug
1291662 extraction tool
RS D seires
Search for AMP DIN 72585
395-7381 2.5mm crimp pin contact, wire is 1-2.5sq.mm 929968-1
395-7369 2.5mm crimp pin contact,wire is 0.5-1sq.mm 929967-1
395-7375 2.5mm crimp socket contact, wire is 0.5-1sq.mm 929974-1
395-7397 2.5mm crimp socket contact,wire is 1-2.5sq.mm 929975-1
http://www.bimmerforums.co.uk/forum/...ell-rs-t73387/
