Electrical Looking for switched power for dashcam
Hi all
I'm trying to hard-wire a dash cam into my 2005 convertible.
I'm mounting the camera next to the sun visor.
Is there ignition-switched power inside the map light/convertible button assembly? That would be super convenient.
Alternately, I'll run the wire inside the A pillar plastic, down the driver or passenger side, into the dash... Where would the best destination for switched power be?
Lastly, what are the slits in my map light assembly for? I don't have the auto A/C unit, would they be sensors for that? Can i cover them with the dash cam?
thanks!
thanks!
The slits are meant to be used by an OEM bluetooth microphone (hidden behind the slits). I believe that rectangular piece just pops out.
If you have an auto-dim or Homelink mirror, or auto headlight/wipers, there is definitely switched power in that console unit. I'd have to look at wiring diagrams at home for a specific line.
My model year was pre-bluetooth. Perhaps they planned ahead.... If there's nothing behind it, then I'll cover it with my cam.
I don't have a fancy mirror or auto wipers or headlights. Do you think they still ran a cable harness with switched power up there?
I have the bentley manual, but i've found it to be lacking in useful wiring information. I hadn't even thought to consult it for this info.
Do you think there's enough room in that panel for a small 12v-5v power supply for the cam?
thanks!
thanks!
Pop the stock light housing out and you'll see that there's some room up there. You could likely squeeze in power adapter but you might need to take it out of it's stock housing. (I'm presuming it'd be one of those things that plugs into the cigarette lighter socket.)
And if there's no switched power up there, you could likely run it up the A pillar and across the front to the center under the plastic trim.
A good wiring schematic should be able to tell you whether or not there's switched power up there or not. I'm betting there is and I'd bet that the power that goes to the antenna is switched. You could easily tap off of that as a power supply for a camera isn't going to draw much.
The antenna, at least on the cab, is powered. An amplifier, I believe. So, it would likely be a switched circuit as i can't believe it would be on all the time. However, you bring up a good point in that it might be tied to the stereo and then be off when the stereo is off. You'd have to test it.
I looked at the wiring diagrams and didn't see anything up there directly switched through the ignition switch. There is wiring coming from control modules (e.g. body control module, convertible roof module) that might be effectively switched power, but those modules are black boxes and wiring diagrams don't show whether they are switched. If you probe around with a meter, you might very well find a switched power line.
Or you can use an Add-A-Circuit to tap off of a switched fuse: F6, F7, F9, F10, F11, F13, F29, F35, F36, F39, F40
My post from a while back: https://www.northamericanmotoring.co...ml#post2979718
There actually was an OEM Bluetooth for 1st gen models -- that's why there are phone buttons on the steering wheel. However, it was something like $2000 and almost nobody has it. There is nothing behind the slots.
I don't have steering wheel phone buttons, only radio and cruise control. It's also an R52, not a 50.
I picked up an add-a-circuit and i'll just run the wire behind the A-pillar into the area behind the steering wheel. This way, when the cheap power converter dies, i'll have an easy time replacing it.
thanks!
thanks!
Assuming i don't want to use an add-a-circuit, where, under the steering-wheel area would i grab a wire coming off the accessory fuse(s)?
Sailorlite
09-04-2015 07:03 PM
09-04-2015 02:34 PM
doug5g
09-02-2015 04:53 PM
