Electrical Battery replacement - Interstate compatibility??
Old Apr 25, 2011 | 10:27 AM
A2GB's Avatar
A2GB
I have a 2005 MINI Cooper S & it needs a new battery. Interstate makes a compatible - MegaTron 47 / 590 CCA / 75 month battery
Has anyone used this? In replacing, does anything need to be re-set? Service at the dealer is non-committal - "You might need this..." "Maybe your check engine light will come on..." "I can't really say..." "Maybe you could bring it in (even though he knew I couldn't).
The car, stored for the winter, is miles from anyplace. My goal is to purchase the battery, drop it in...then have it run like a champ :-)
If anyone knows of anything else I should anticipate, I'd appreciate your advice. Thanks a million!
Old Apr 25, 2011 | 11:04 AM
cristo's Avatar
cristo
Alliance Member
Here's a thread for R53 battery compatibility.
https://www.northamericanmotoring.co...s-for-mcs.html
On mine, I lose the settings for the clock, side window initialization,
trip odometer reading, and dash light brightness if I don't keep 12V
on the system when I change the battery.
Write down the trip odometer reading before you change it if you're
using it to figure gas mileage, the other things can be reset easily in a couple minutes.
Old Apr 25, 2011 | 11:44 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
You have an S, so the cars battery is in the cabin area. And this particular battery appears not to be a sealed type like an optima. And, it does not appear to have a venting hose like the MINI's battery. So it will be venting into your cabin.
That said, it's not compatible.
stevepsd
35
Dec 6, 2022 03:22 PM
woodstudio
Mar 15, 2020 08:28 AM
polotska
Aug 23, 2015 03:03 PM
scottrn
Aug 22, 2015 07:26 PM
jeremy_reyes94
Aug 12, 2015 10:56 AM
