Electrical Making the alarm light blink?
Old Apr 27, 2011 | 12:02 PM
  #26
Chernobyl's Avatar
Chernobyl
Originally Posted by GTECKO
...one thing though, when trying to Open a door or the hatch it doesn't cause the hazard lights to flash
How exactly are you unlocking the door to open it? (I assume you didn't actually smash the window to reach in!). You have to be careful that you aren't inadvertently disarming the alarm during your test. Note that if you lock the car using the fob INSIDE the car, it will not arm the alarm.
Try this test: key on, roll down the driver's window, key off. Get out (take the fob!), and lock the door using the fob button (or the button in the door handle if you have Comfort Access). The alarm light should start flashing.
Now, reach in the open window, and open the door using the inside handle (it'll take two pulls since the first one unlocks only). Your hazards should start flashing (imagine annoying siren noise accompaniment).
Old Apr 27, 2011 | 12:13 PM
  #27
GTECKO's Avatar
GTECKO
No I didnt try that ...
What I did is, locking my doors with fob and then pretending to open the door or the hatch hahahaha
Old Apr 27, 2011 | 01:09 PM
  #28
strobeyprobey's Avatar
strobeyprobey
That video is sweet! Now I really want to do this mod. Of course, I was just thinking about getting the actual alarm (not that I need it) for less then $200.
Old Apr 27, 2011 | 01:21 PM
  #29
pjv1k's Avatar
pjv1k
wish there was someone near me that new how to do this.... im lost with this programming stuff..
Old Apr 27, 2011 | 02:14 PM
  #30
GTECKO's Avatar
GTECKO
Was a bit tricky with that error I got but thanks to Chernobyl, worked out perfectly.
Btw, tried what you said and yes the flashers goes on
Now, what do you think of this draining the battery on a long term basis if you dont drive the car or something ???
Old Apr 28, 2011 | 01:15 PM
  #31
HarleyDS's Avatar
HarleyDS
Last night I was exchanging some emails with Chernobyl and thanks to him I was able to make it work !!
If you guys see my previous msg #22 - I had an error. So Chernobyl idea is using the V32 files in the c:\ediabas\ecu folder and V38 (for me) for everything else.
worked like a charm, check out the video
I can get the video to be in the post
here is the link
two things:
would this light on all the time drain the battery ........
Did you do this on OSX or Windows? I noticed you have a MBP hooked up..
Old Apr 28, 2011 | 01:33 PM
  #32
GTECKO's Avatar
GTECKO
Iam running Windows7 with bootcamp Good eye
Old Apr 28, 2011 | 02:20 PM
  #33
WAGO's Avatar
WAGO
Anyone in the Los Angeles area that can do this?? I'll pay for this service.
Old Apr 29, 2011 | 09:26 AM
  #34
HarleyDS's Avatar
HarleyDS
I plan on doing this after some more reading, but I'm in Florida. If anyone else wants this done, ping me and we can work out a price so I can offset the price of the cable and sell it to my wife better. Right now, she is against me getting a $90 cable!
Old May 3, 2011 | 06:19 PM
  #35
BBoshart's Avatar
BBoshart
I was finally able to read my SPEG module and make this work! But one question. Why does the KOMBI module need to be coded as well? Right now my alarm light is working after only coding the SPEG module. Is there a specific purpose to coding the KOMBI? Or was it just coded at the same time and assumed it is needed to make the light blink? I hate coding the KOMBI if I don't have to as it resets the trip odometer, gas mileage, etc. Thanks.
Old May 3, 2011 | 06:43 PM
  #36
GTECKO's Avatar
GTECKO
Did you use the file I gave you to make it work ?? what was the problem, I saw you posted somewhere you had a BEST error ?
I coded both as thats what Chernobyl had said, however if it works only with SPEG than good
Btw, isnt it a sweet mod
Old May 3, 2011 | 06:56 PM
  #37
BBoshart's Avatar
BBoshart
I could not get it to work with the newer version of EDIABAS. I tried using the new ECU files, old ECU, tried using V38 and V40 DATENS. Pretty much every combination I could think of. I finally reinstalled the older version of EDIABAS that I have been coding with and used the newer V38 DATENS and SDGAT files you have posted and it worked.
So I'll just stick with my older version using the newer DATENS. It works for me.
Old May 3, 2011 | 07:10 PM
  #38
GTECKO's Avatar
GTECKO
I thought you had seen the email I sent out.
You had V34 I believed but in order for it to work, the set up I used was the V32 files in the c:\ediabas\ecu folder
and
V38 or V40 for everything else.
I believe the problem is v34 for ediabas.
Anyway;worked out
  #39
Chernobyl's Avatar
Chernobyl
Why did I say to code both? Well, since the alarm LEDs are mounted on the tach I just assumed that the KOMBI would also need to be coded to receive and display the "alarm armed" indication from the SPEG. I never tried each one individually. If coding the SPEG is all that is necessary - great!
And I also hate coding the KOMBI for the same reason - wipes the trip meter, clock, etc.
Old May 3, 2011 | 07:21 PM
  #40
CoolantGuy's Avatar
CoolantGuy
Nice
Anyone in CT. U.S.A. have the capability to do this ?
Thanks in advance. Asked dealer today if they new anything about it and of coarse they didn't they told me to copy from here and there sure their techs could do it . Mike.
Old May 3, 2011 | 07:42 PM
  #41
slimjimtell's Avatar
slimjimtell
Helix and Way Motor Works were doing it at the Dragon.
Old May 3, 2011 | 09:04 PM
  #42
BBoshart's Avatar
BBoshart
Ok thanks. I wasn't sure if not coding the KOMBI would result in some type of error. I guess I'll leave it alone since it's working!
Old May 8, 2011 | 06:05 PM
  #43
jasoncolorado's Avatar
jasoncolorado
Where can you find the factory alarm for under $200? Thanks.
Jason
Old May 8, 2011 | 06:10 PM
  #44
strobeyprobey
Sorry, it isn't always under $200.
http://www.realoem.com/bmw/showparts...17&hg=65&fg=95
Production date up to 9/09 is $178 on parts.com (65730445530)
Production date from 9/09 is $213 (65120443179).
Old Jun 13, 2011 | 06:26 PM
  #45
walk0080's Avatar
walk0080
Yes, with one qualification: I believe MINI stopped adding the alarm pre-wiring starting with MY 2011. So I don't know if the light is even hooked up in later model cars. BTW: KOMBI = instrument cluster module, SPEG = smart power electronics gateway (chassis module).
Anybody know if later 2011 cars still have the alarm light connected??
Old Jun 20, 2011 | 10:28 PM
  #46
SpyVsSpy's Avatar
SpyVsSpy
Is there anyone in Seattle that can do this Mod?
Old Jun 20, 2011 | 10:46 PM
  #47
spooky30's Avatar
spooky30
Not sure...but I wish I could find someone in San Diego to do this...btw, I have a sparkling silver cooper...love it!
Old Jun 27, 2011 | 04:10 PM
  #48
gr8ful's Avatar
gr8ful
No wiring on 2011 car unless factory alarm ordered.
Old Jun 27, 2011 | 04:13 PM
  #49
walk0080's Avatar
walk0080
That's too bad but thanks for confirming.
Old Jul 22, 2011 | 08:38 AM
  #50
rolant's Avatar
rolant
I tried on my R56 2011 but no heartbeat. sad but true.
