Electrical Moving the Microphone
Old Aug 27, 2012 | 06:11 AM
  #26
nd3boy's Avatar
nd3boy
The wire wasn't long enough to move it to the driver side. I pulled and tugged it alittle and wouldn't budge. So its back in its original spot.
Old Sep 29, 2012 | 09:46 AM
  #27
PepeR60's Avatar
PepeR60
nd3boy, mine was not long enough to route it through the same hole (up top) on the opposite side, but I could route it through the larger hole that is just to the side of where the microphone sits. Also, there is at least one other harness end up there that you may need to get around to give you a touch more length.
Old Sep 29, 2012 | 05:46 PM
  #28
detours's Avatar
detours
I moved mine over last week. Like others have noted, the wire is barely long enough to make it through the hole near the center. My wife says it makes a big difference and she can finally hear me when I use bluetooth in the car.
Old Oct 1, 2012 | 08:33 AM
  #29
80jpm's Avatar
80jpm
I moved it over about 10 minutes ago. I won't get to fully op-test it until after work, but voice commands seemed to work better. That is officially my first modification to any car ever. I feel very proud at the moment.
Old Dec 21, 2012 | 11:42 PM
  #30
MiniDan's Avatar
MiniDan
Today I took delivery of a 2013 Countryman. They have apparently placed an additional microphone above the driver's seat; see the red circle in the attached photo.
FWIW, I placed a call to my wife while driving on the freeway at 70mph and she said I sounded fine.
Old Jan 11, 2013 | 02:29 PM
  #31
lph2's Avatar
lph2
Originally Posted by y8s
....Be careful if you plan to stick your finger in the second cover's holes. There are some sharp edges as evidenced by the flesh wounds on my index fingers.
Amen!
I moved mine a few days ago!
I took delivery on 12/12.
I'm surprised they hadn't moved it!
Old Jan 11, 2013 | 03:11 PM
  #32
Koopah's Avatar
Koopah
Originally Posted by lph2
{snip}...I'm surprised they hadn't moved it!
You know, they DID move it! In the UK, the microphone in on the left side of the cabin not the right. Really!
Old Sep 11, 2013 | 04:32 PM
  #33
UnminiSCAll4's Avatar
UnminiSCAll4
I wonder if we can add an extra microphone above the driver as well like the 2013 model
Old Sep 14, 2013 | 06:52 PM
  #34
Koopah's Avatar
Koopah
RealOEM shows the 2013 having only one microphone. Perhaps what is shown in MINIDan's picture is THE microphone, not a second microphone.
Old Sep 14, 2013 | 08:51 PM
  #35
UnminiSCAll4
MiniDan can you clarify? Since you stated there is an "additional microphone" in the 2013 model. If its possible I wouldn't mind doing a mod on this.
Old Sep 17, 2013 | 08:32 PM
  #36
MiniDan's Avatar
MiniDan
Yes, I worded that post carelessly. I believe there is a single microphone in that new position, with no microphone elsewhere.
randeez
Oct 5, 2015 09:23 AM
Pedro99
Oct 3, 2015 10:56 AM
MINI Stupor
Oct 1, 2015 11:36 AM
point665
Sep 29, 2015 12:41 PM
Emnotek
Sep 29, 2015 07:37 AM
