Electrical looking for ignition wiring
Old Oct 12, 2010 | 11:10 AM
omniscott's Avatar
omniscott
I am in need of the following wiring and place? 2010 mini
12V constant
Ignition
Starter
Horn?
Old Oct 12, 2010 | 11:32 AM
strobeyprobey's Avatar
strobeyprobey
You can find constant and "ignition" power at the fuse box.
But why would you need starter? There really is not a starter signal unless you go to the starter motor itself. If I remember correctly, the Car Access module sends the start signal to the car computer over the CAN bus when the proper security with the DME has been authenticated (the FOB serial code is authorized).
Horn would be easiest at the horn.
If you look at the WDS found here, more correct information can be determined. Also keep in mind there probably has been changes since 07.
http://www.mcaw.info/wds/mini/us/r56/index.htm
You need IE 32bit, Java & Adobe SVG plugin
Old Oct 12, 2010 | 11:49 AM
omniscott's Avatar
omniscott
it is for gps tracking with started kill.
Old Oct 12, 2010 | 11:54 AM
strobeyprobey
The MINI and BMW will not start or run without the proper security authentication. So basically if they don't have one of your key FOBs in the slot, the car will not run (you won't even get "ignition" [they call it something different] power).
Now if it is a relay control to disable the start sequence, there could be a wire right at the start button you could bypass.
Old Oct 12, 2010 | 12:22 PM
omniscott's Avatar
omniscott
thanks
Filmy
15
Jun 6, 2023 06:27 AM
Sep 10, 2019 09:22 PM
MiniUnz
Sep 14, 2015 11:11 AM
Filmy
Sep 7, 2015 08:27 PM
