Electrical LED Rear Foglights
Old Apr 5, 2010 | 12:26 AM
  #26
JustinGTP's Avatar
JustinGTP
Usually .5 or 1 hour.
Old Apr 5, 2010 | 11:33 PM
  #27
smoke05S's Avatar
smoke05S
So programming can potentially cost more than the original option without parts? Ouch.
Old Apr 10, 2010 | 05:29 PM
  #28
Lil Q's Avatar
Lil Q
And some dealers still claim they can't program them in. I am much happier with them as brake/tail light than as fog lights. Especially since they still work as fogs as the time you need them....assuming you are the type of driver to actually turn on your lights in inclement weather....but if you aren't well they have the same affect off in the fog as when they are off as brakes.
Old Apr 15, 2010 | 11:20 PM
  #29
smoke05S's Avatar
smoke05S
Looking at those lights closely, they have lenses on each LED. Typically that type of LED draws about 20ma each. It looks like your total current draw for each light is about 300mA (if I am off by a factor of 10 it will still work, you can verify with a VOM if unsure). If you run into a deadend at the dealer or want a less expensive way to connect the lights (prepare for a $170.00 programming fee), 300ma is not going to blow a fuse or anything if you simply tap into the front foglights. You are technically meeting all laws because there is an indicator present when they are on. It is about 1/2 hour worth of work to splice in and run a line up to the front fogs and you are done.
If it is any consolation I am using LED bulbs with 26 elements each in my rear fogs so the current draw would be similar. I spliced them together and go forward with 1 wire to one front fog and have no fuse or bulb warning problems.
Old Apr 22, 2010 | 05:37 PM
  #30
ghosthound's Avatar
ghosthound
hmmm any pix of them on?
id probably put some tint on the lenses though, not a fan of the clear lens
Old Apr 23, 2010 | 04:57 PM
  #31
mickeyR57sparkling's Avatar
mickeyR57sparkling
Originally Posted by superc00per
ok finally some installed pics. i still haven't had a chance to get them programmed. i'm waiting to do my wheel changeover and then get them turned on while i'm at the dealer. should be in two weeks or less.
I picked up the same lights on EBAY.... here is the ebay store.
http://shop.ebay.com/weitzu2001/m.ht...&_trksid=p4340
My plan, being that we dont have a big fog issue in the US, is to tie them into the brake lights. Here is a company that can assist with that, and there is no need for programming.
http://www.gominigo.com/BLK-MINI.html
Also, in order to match the clear on Blk fog lights, im thinking about getting these tail lights.
http://cgi.ebay.com/ebaymotors/ws/eB...category=33713
Has anyone found where i can get a replacement LED "Clear" 3rd brake light for the R57 Cabrio? I cant find it anywhere....
Old Apr 23, 2010 | 06:31 PM
  #32
blitzcat's Avatar
blitzcat
Every time I do a club drive, we end up driving very fast in and out of the clouds. Rear fogs were my biggest oops in ordering my car. So I'm waiting to see how these lights turn out.
There are 5 minis in this photo.
Old Apr 24, 2010 | 05:12 PM
  #33
mickeyR57sparkling
they are on ebay, do a search for JWC LED rear fog lights
Old Apr 24, 2010 | 05:15 PM
  #34
mickeyR57sparkling
i think if i were to run them as rear fogs, i would just splice them into the front fogs, and they would come on together. That way no tricky switch work and no reprogramming, and no bulb warnings.....its all good!
Old Apr 24, 2010 | 05:26 PM
  #35
blitzcat's Avatar
blitzcat
I think someone already ordered them all. Nothing listed ATM.
Old Apr 25, 2010 | 02:47 PM
  #36
mickeyR57sparkling
LED Fogs INSTALLED AND LIT!!!!
Sorry to hear they are currently not listed, but they are on from time to time...you can always call http://www.ciraya.com/Info.htm. they shouldnt cost more then $65
Here are mine installed.....the part i wasnt expecting was that when i hooked them up i got Parking and Brake lights!!!!
No Bulb out warning!
This shot is before the LED Tail Lights are installed and the rear Sport Stripes...STAY TUNED!
UPDATE! Here is the link that explains how i installed them:
https://www.northamericanmotoring.co...ake-lites.html
Attached Thumbnails LED Rear Foglights-parking.jpg   LED Rear Foglights-brake.jpg
Last edited by mickeyR57sparkling; Jun 14, 2010 at 06:10 AM. Reason: meant to say "they shoudn't cost more then $65"
Old Apr 25, 2010 | 08:45 PM
  #37
mickeyR57sparkling
here is one on EBAY, although its a little more then i paid, but not too bad.
http://cgi.ebay.com/R56-R57-JCW-John...item3a5a36d01f
Old Apr 26, 2010 | 03:24 AM
  #38
ngweibing's Avatar
ngweibing
do it have it for 1st gen?
Old Apr 26, 2010 | 10:14 PM
  #39
JustinGTP's Avatar
JustinGTP
LED taillights?
Old Apr 26, 2010 | 11:02 PM
  #40
smoke05S's Avatar
smoke05S
+1 Let's hear about the LED tail lights
Old Apr 27, 2010 | 07:40 AM
  #41
mickeyR57sparkling
From what i can tell, they only have fog lights for 2ng gen cars that have the removable black plugs in the rear bumper.
here is the Ebay Store for the Tail Lights
http://stores.ebay.com/Gear-Jammin-A...vcZ1?_nkw=mini
I should have them this friday, i will update with more pics then...
Has anyone seen a clear LED 3rd brake light for the R57 Cabrio?
Old Apr 17, 2011 | 03:31 PM
  #42
5zero4's Avatar
5zero4
Out Motoring has LED tailights to match those now. $285... not bad...
Old Apr 17, 2011 | 04:03 PM
  #43
AXO's Avatar
AXO
They look Great!!!!!
caiken
Aug 27, 2015 06:55 AM
HCClubbie47
R55 :: Clubman Talk (2008+)
Aug 24, 2015 02:16 PM
I_drive_slow
Aug 18, 2015 10:47 AM
