Electrical H/K wiring question??
Old Sep 17, 2003 | 08:41 AM
200mph's Avatar
200mph
I bought all the parts and wiring connectors from a wrecking yard to retrofit the H/K system to my US spec Mini. No H/K specific wiring harnesses. The standard wiring wont work... not enough wires for all the H/K drivers.
Is anyone interested in taking the connectors and making up the harnesses from them? I dont have the time, nor do I have yards of twisted pairs or color-coded wire.
Or, if you replaced your H/K with an aftermarket setup, I'll buy any or all of your unaltered H/K wiring. The harnesses are:
head unit to amp
head unit to left door speakers
head unit to right door speakers
rear speakers to amp
Thanks.
Old Sep 17, 2003 | 05:49 PM
GBMINI's Avatar
GBMINI
Correction:
All speakers are wired to the amp, not the head unit.
Where are you?
I think you would find it easier to retrofit by running wires and making connectors in the car as you go, instead of having someone make a harness and trying to drop it into a built car.
Old Sep 18, 2003 | 09:23 AM
200mph's Avatar
200mph
Oops, right about the amp>speakers wiring.
Actually, the instructions (which I finally found) for the retrofit kit call for laying in a new harness, and it doesnt look that difficult... door panels and rear seat need to come out, etc.
The problem now is: MINI USA is saying that the H/K retorfit kit was designed and specced but not produced for sale.
Dos that mean that the harnesses I am looking for (and have BMW/MINI part #'s) dont exist?
Wondering is I can use an OE "hi-fi" harness??
I'm in NC.
Old Sep 18, 2003 | 09:33 AM
02s79fj40's Avatar
02s79fj40
Whats the part number for the retrofit kit? I have access to the mini etk, and could tell you if the number is any good.If it's a good part number any dealer should be able to order it for you.
Old Sep 18, 2003 | 09:39 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
OK, 200mph-
It sounds like you have the stock audio. You wish to add HK upgrade aftermarket.
You have the HK hardware and wish to install it into your MINI?
You don't have the HK harness preinstalled.
So now you do have connectors for HK items from wrecking yard (poor MINI)
<<Is anyone interested in taking the connectors and making up the harnesses from them? I dont have the time, nor do I have yards of twisted pairs or color-coded wire.
For someone that really knows what they are doing this is OK and possible. for most of us it would be too time consuming for the labor. You'd be creating an HK wiring harness.
<<Or, if you replaced your H/K with an aftermarket setup, I'll buy any or all of your unaltered H/K wiring. The harnesses are:
head unit to amp
In theory this sounds possible but the problem is that the HK harness is totally buried in the wiring of your MINI so people that have HK and upgrade to something better do not touch the HK harness and pull it out- that would be a total mess and very costly. So they leave the harness in and cable/wire around it.
I have been told by the MINI dealer that the labor to pull or install a full HK harness is expensive and time consuming. Further if you do not know what you are doing it can become a BMW wiring nightmare.
I don't like bad dreams so I will steer clear of bad wires.
As an idea- if you have the HK components and the connectors can you not ask a Very good audio installer to set it all up in a MINI? Wire as you go instead of making a full harness? I guess if you look at the cost of expensive Cables vs the harness it varies in complexity, cost, installation hassle, noise, etc.
Good luck.
Old Sep 22, 2003 | 07:36 PM
200mph's Avatar
200mph
Thanks to both. I've had parts managers in the US and UK run the harness part numbers and they are good numbers... they are just not available separately. They are only available as part of the upgrade kit, which is not available.
I do have the wiring diagram for the H/K upgrade, so it looks like I'll be doing the wire it as you go route. Hope I can get this done before its time to sell the MINI!
Old Sep 24, 2003 | 02:39 AM
minihune's Avatar
minihune
OK, keep track of how many hours of labor are required and if it works out OK for you in the end.
Good luck. Keep us posted.
Old Oct 13, 2003 | 09:22 PM
Donald's Avatar
Donald
Hi 200 MPH,
Do you have the wiring diagram for the H/K upgrade? Can you email to me? or just post in here, because I really need this rundown to connect to the aftermarket amp.
email address: belenlip@adelphia.net
AZN Optics
Accessory Products
Aug 21, 2015 02:03 PM
AZN Optics
Aug 21, 2015 02:02 PM
Getrieben
Aug 15, 2015 09:09 PM
yashmack
Aug 15, 2015 03:11 PM
CARdiac
Aug 8, 2015 03:30 PM
