Electrical 6th gear dumb question...
Old Sep 20, 2007 | 05:10 PM
MSFITOY's Avatar
MSFITOY
sooo...is the high beam adjustable? Mine seems to be aiming below the low beam...I have Xenon and I don't see a seperate adjustment ****...
Old Sep 20, 2007 | 06:01 PM
MSFITOY's Avatar
MSFITOY
Looks like I'm good at asking questions that no one can answer here...
Old Sep 20, 2007 | 06:39 PM
gnatster's Avatar
gnatster
Gosh Sid it was only 50 min. before you gave up.
Anyway the Xenons don't have an adjuster that I can see in the Bentley Manual or under the hood. They do have a self leveler thats supposed to keep them correct.
That said I've had an issue with one of mine doing the same thing. Turns out the housing had slipped some in the assembly from having to slam the hood. It was easy to fix by pulling out the high beam bulb and rocking the housing back into place. Might want to take a look at that. Otherwise I got nothing.
Oh wait, I should not be answering this as I'm not up to 6th gear yet.
So...[Emily Litella] Never mind [/Emily Litella]
Old Sep 21, 2007 | 05:47 AM
MSFITOY's Avatar
MSFITOY
I'll look again but it seems like the high beam cans are mounted solid without any adjustments...but they're aiming low...I don't drive at night very often and even less with high beams on as I'm in the suburbs but it looks like the high beams does little of anything to reach out...
Old Sep 21, 2007 | 05:55 AM
kyriian's Avatar
kyriian
there are 2 adjustment black plastic screws back there that u can use to adjust the xenons up, down, and left right... unless you are talking the highbeams as in the halogens... then im not aware if there's adjustments
Old Sep 21, 2007 | 06:01 AM
MSFITOY's Avatar
MSFITOY
Yes...high beam...am I right that there is NO adjustment for high beam?
Old Sep 21, 2007 | 06:21 AM
ca$per's Avatar
ca$per
I face the same problem some times as I can see that my High beam is lower than my Xenon... I noticed that if I keep the high beam on for around 30 seconds or so, the light will self adjust and go up... try it out and it might work for you.
why it does this? I have no idea good luck
Old Sep 24, 2007 | 04:40 AM
NMgokart's Avatar
NMgokart
Hi Sid,
You should be able to get higher highs if you adjust the whole housing up, via the adjustment screw on the back. What you will do is raise the whole assembly, and then the self- levelers will take care of the lows. (I'm going on intuition here, but it makes sense if you think about it). I think it is the inboard adjuster that moves them vertically.
Here's some light reading:
https://www.northamericanmotoring.co...aim+headlights
Old Sep 24, 2007 | 05:34 AM
MSFITOY's Avatar
MSFITOY
Originally Posted by 3cocinas
Hi Sid,
Hey thanks for the link...I'll do some investigation...
Old Oct 11, 2007 | 07:59 PM
skillet's Avatar
skillet
What did you come up with Sid? Did this take care of your problem?
Old Oct 12, 2007 | 05:38 AM
MSFITOY's Avatar
MSFITOY
I haven't driven at night lately and forgot about it...
unxpectederror
Oct 22, 2015 12:16 PM
MINI Stupor
Oct 1, 2015 11:36 AM
patsum
Sep 30, 2015 02:10 PM
bahman
Sep 30, 2015 01:59 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
