Electrical Hot or Not (Fuses)
Old May 9, 2026 | 07:25 AM
  #101
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Originally Posted by Mr&MrsKenmore
Does the inside fuse panel have a 100% constant battery feed that never drops out? I need to provide continuous power to my Android HU. Right now I am using the old "continuous" radio power feed which I learned is timed to 30 minutes after keyfob removal.
What is the build date of your car? See sticker in your driver door jamb.
Old May 9, 2026 | 07:30 AM
  #102
Mr&MrsKenmore's Avatar
Mr&MrsKenmore
Originally Posted by maybe, maybe not
what is the build date of your car? See sticker in your driver door jamb.
04/09
2009 R56 non-S, non-HK
Old May 9, 2026 | 08:23 AM
  #103
Maybe, maybe not
Community Builder
Based on Bentley wire diagrams, all JBE fuses listed below are "hot all of the time" because they receive power directly from 125A fuse F60 in A406 fuse box in engine bay.
Fuse F2 from 12/2008
Fuse F3
Fuse F5 to 11/2008
Fuse F8
Fuse F9 to 11/2008
Fuse F11 from 12/2008
Fuse F22 to 11/2008
Fuse F23 to 11/2008
Fuse F24 to 11/2008
Fuse F24 from 12/2008
Fuse F25 to 11/2008
Fuse F25 from 12/2008
Fuse F26 to 11/2008
Fuse F26 from 12/2008
Fuse F27 to 11/2008
Fuse F27 from 12/2008
Fuse F28 from 12/2008
Fuse F29 from 12/2008
Fuse F30 Clubman from 12/2008
Fuse F34 to 11/2008
Fuse F36 from 12/2008
Fuse F38 to 11/2008
Fuse F39 to 11/2008
Fuse F40 to 11/2008
Fuse F40 Clubman from 12/2008
Fuse F40 from 12/2008, except Clubman
Fuse F41 from 12/2008
Fuse F42 from 12/2008
Fuse F43 to 11/2008
Fuse F43 Clubman from 12/2008
Fuse F43 Convertible from 12/2008
Fuse F44 to 11/2008
Fuse F46 to 11/2008
Fuse F46 from 12/2008
Fuse F47 to 11/2008
Fuse F47 from 12/2008
Fuse F48 to 11/2008
Fuse F48 from 12/2008
Fuse F49 to 11/2008
Fuse F49 from 12/2008
Fuse F50 from 12/2008 except Convertible
Fuse F51 from 12/2008
Fuse F52 from 12/2008
Fuse F53 from 12/2008
Old May 9, 2026 | 08:35 AM
  #104
Mr&MrsKenmore
Terrific. Looks like F3 will be a good option for me.
Old May 9, 2026 | 08:56 AM
  #105
Maybe, maybe not
Community Builder
Old May 9, 2026 | 09:35 AM
  #106
Mr&MrsKenmore
I am double checking everything now. Waiting for 30+ minutes to go back just confirm they stay live. Working through the open window LOL.
Old May 9, 2026 | 09:40 AM
  #107
Maybe, maybe not
Community Builder
Good luck!
Old May 9, 2026 | 09:58 AM
  #108
Mr&MrsKenmore
So both F3 and F38 passed the 30+ minute test. Appears to be all good. I have a kinda crazy idea. Could I use an inline fuse holder and crimp male blades on each side. I would stab one side into the 12V+ constant of F3 and then on the load side of the circuit serving the radio (removing the fuse)? This would eliminate the need to take everything apart in my dash. I need to figure out what fuse exactly provides power to my Android HU. I think F45. I wish we had access to proper wiring diagrams.
UPDATE - Figuring this out was a bit of a challenge. I was unable to 100% determine which circuit had the "constant/30 minute delayed" battery power. I did figure out the F23 is the circuit powering to the radio and the tach above the steering wheel. F23 is normally off, on when you unlock and key not on, on when key on. This could be it. It powers multiple things as I suspected so my crazy idea is out.
With the radio on, pulling F13, F5 and F45 did nothing. No change. Radio stayed on normally.
Old May 9, 2026 | 02:49 PM
  #109
Maybe, maybe not
Community Builder
Old May 9, 2026 | 05:40 PM
  #110
Mr&MrsKenmore
Great info. So it splits off many ways. Looks like I will be keeping it simple and doing a new circuit direct to the radio for constant battery power.
Shadow05MCS
15
May 7, 2026 02:31 PM
871 MCS
Aug 4, 2019 05:00 AM
cereal
Nov 24, 2017 10:27 AM
hellomoto
Nov 13, 2013 07:22 AM
bdrecksage
Oct 20, 2013 11:22 AM
