Electrical Gauges - water temp vs oil pressure
What gauge would be more valuable to a daily driver, water temp or oil pressure?
Which one should be mounted on the steering colomn with the boost gauge and which one should go down below under the toggle switches?
Thanks.
Thanks.
EXCELLENT question and I'm going to be watching this thread. I'm disappointed that the temp gauge is a "dummy" gauge and I'd like to install aftermarket gauges to give me a better idea of what's going on in the engine compartment.
I mounted the boost & oil pressure on the column. I have plans to mount an AFR gauge soon as well. I'll most likely put it where the oil pressure is. I might move the oil down by the switches and add water temp down there too. The oil pressure is a trip to watch, it's really all over the place it ranges from 10 or 12 to over 100psi depending on temp & RPM. You can use it to tell when the oil is at full/normal temperature. I've never see an oil pressure gauge move so much. I think most OEMs must filter it to make it look more stable.
http://www.spatechnique.com/product_pages/index.asp
Larry's right, they are expensive.
WOW!
I'll say.
Kimolaoha
Jul 5, 2023 01:04 PM
tylewis
Aug 18, 2015 06:53 AM
Lex2008
Aug 16, 2015 08:33 PM
