Digital Torque Wrench - Special
Old Jan 13, 2012 | 07:53 AM
BLMW's Avatar
BLMW
We have gotten a number of requests, so we are going to re-run this special for the month of May.
As a new vendor on this forum, we are offering an introductory special: our Digital Torque Wrench w/ Blow Molded Case for $99 - including shipping. Just go to our website: Brown Line Metalworks, LLC | Professional Grade Digital Torque Wrench and click on the "Buy Now" button. At checkout, enter the coupon code: NAM
You can see the torque wrench in action in the following video:
Product Specifications
Patented Double Gear Sensing System
Designed, engineered, and tested by Brown Line Metal Works, the patented* D.G.S.S. technology ensures repeatable accuracy of +/- 3.5% both clockwise & counter-clockwise
Accurate from 20 – 100% of full scale (7% accuracy from 10 – 20% of full scale)
Microprocessor Controlled
8-bit electronics ensures accurate readings and simplicity of use
Allows for both Peak and Track mode
Individually calibrates each wrench
Supplies unique serial number for each wrench
Ratchet Head
1/2" drive reversible ratchet
32-tooth gear provides an 11.25º arc while handling high torque loads
Forged from Chromium Vanadium alloy to ensure strength
Conforms to ASME B107.10 2005 standards
Range
15 – 150 ft/lbs
180 – 1,800 in/lbs
20.3 – 203 Nm
Digital Control
Large backlit digital display shows both target torque and current read-out
Intuitive button design makes operating torque wrench simple
LEDs and digital display provide visual feedback when operating wrench
Buzzer creates audible feedback when target torque is reached
Easily switch between ft/lbs, in/lbs, and Nm
Automatically powers off when not in use for 2 minutes
Low battery indicator
Handle
Soft-touch overmold provides comfortable non-slip grip
Engineered plastics ensure an impact resistant housing
The offer is valid until June 1st, and is only for the lower 48 states.
Old Jan 21, 2012 | 06:06 AM
putttn's Avatar
putttn
I recently broke my Craftsman torque wrench and just happened to see this add. So, since these guys are advertising here and the wrench has good/excellent reviews, I ordered one and just received it.
My initial impression is that it's a quality tool at a great price. If you need a torque wrench I'd give this a 5 star recommendation.
Old Jan 25, 2012 | 07:54 AM
BLMW's Avatar
BLMW
17 Days left - don't miss out!
Old Jan 30, 2012 | 07:34 AM
BLMW's Avatar
BLMW
12 Days Left.
Old Feb 10, 2012 | 10:06 AM
BLMW's Avatar
BLMW
1 Day Left!!
Old May 2, 2012 | 08:02 AM
BLMW's Avatar
BLMW
We have gotten a number of requests, so we are re-running this special for the month of May.
Old May 6, 2012 | 04:48 PM
rum4's Avatar
rum4
I have used mine several times and it works great. Glad I purchased it on the first run you did for the NAM
Old May 7, 2012 | 09:30 AM
quikmni's Avatar
quikmni
Too bad the wrench only goes to 150 ft/lbs. The upper limit is pretty low for a 1/2" drive torque wrench. I need a new 1/2" torque wrench and would be interested if the upper limit was in the 200-250 range. For comparison, the Craftsman digital 1/2" 25-250 lb is $108 right now.
Lex2008
How to
47
Jun 15, 2022 06:18 AM
theateist
Sep 16, 2015 07:22 AM
Denly
Canada
Sep 15, 2015 12:55 PM
hydouken
Sep 15, 2015 05:49 AM
Sep 14, 2015 12:48 PM
