ALTA R56 Boost Tubes
Old Feb 6, 2009 | 11:09 AM
ALTA_JOHNL's Avatar
ALTA_JOHNL
Hello,
We at ALTA listen to our customers and have come up with another great way to treat your R56 Mini S to a new dress-up and power accessory.
Since the beggining of the R56 we have sold our Boost Tube up grade kit. This kit consisted of two hoses to increase flow into the intercooler and out of the intercooler. This is still available for $249.99, click picture to check it out on the ALTA Performance Web Site
NOW we have split that kit up so you can modify your R56 Mini S in your own way or at your own pace.
Longer HOT Side Boost Tube. This is the one that connect to the outlet of the turbo and the inlet side of the intercooler. You can pick this part up for $149.99 on the ALTA Performance Web Site. Click the picture below to check it out on the ALTA Performance Web Site.
Shorter Cold Side Boost Tube. This is the tube that flow directly into the throttle body and manifold. You can pick this part up for $149.99 on the ALTA Performance Web Site. Click the picture below to check it out on the ALTA Performance Web Site.
PLEASE let us know if you have any questions.
Old Feb 6, 2009 | 11:16 AM
ADAMSALTAMINI's Avatar
ADAMSALTAMINI
Hey Guys and Gals,
This is what you folks have asked for and John came through! Only $149.99 for the hot side! What a deal! Plus this weekend there is a significant sale going on as well.
Great time to buy! Questions on the product let me know!
Wanna know how to install them? CLICK HERE!
THANKS AGAIN NAM!
Old Feb 6, 2009 | 01:39 PM
Tsar's Avatar
Tsar
If you don't mind me asking, what is the advantage of having silicone tubes, if any, over hard pipes (hot/cold side)? I was always under impression that latter was more advantageous to have.
Oh thanks for my 2" antenna, just got it today, I like it
Old Feb 6, 2009 | 01:51 PM
ADAMSALTAMINI
Thanks Tsar for the business and for asking.
The boost tubes (from ALTA in Silicone) remove restrictions in the plumbing by increasing the internal diameter, smoothing transitions, and removal of the muffler system built in by the factory.
Hope that helps! Thanks again!
Old Feb 6, 2009 | 02:07 PM
Tsar's Avatar
Tsar
There was a misunderstanding, by hard pipes I meant the ones that Exhaust Depot offers, I'm guessing they are aluminum or some kind of other lightweight metal. I would put a link in here, but I'm not sure if that's against the rules.
My bad about misunderstanding.
Old Feb 6, 2009 | 02:42 PM
ADAMSALTAMINI
No I understand what you are saying. The Aluminum Tubes, to have an OD to match the couplers to the connections, MUST be a smaller ID than the Silicone type tubing. PLUS with the silicone we can make other changes to the bends, curves etc. all to help improve flow, that can't be done with aluminum tubing.
Aluminum tubing isn't bad, per se, just in this instance the ALTA Silicone is a better choice.
Thanks again!
Old Feb 7, 2009 | 12:32 AM
Noegel's Avatar
Noegel
Would that big drop in HP be worth the gains in the middle? Just a question... how noticeable is it? It looks like you lose HP overall.
Old Feb 7, 2009 | 07:12 PM
MiniPOLACK's Avatar
MiniPOLACK
lol, ok you got me, just ordered a set.... for my love....lol
Old Feb 7, 2009 | 08:05 PM
ADAMSALTAMINI
There is a slight drop at the VERY high end as the ECU pulls back boost due the decrease in restriction. The benefit at the mid / low / mid-high MORE than makes up for it. PLUS when the new ALTA ECU Tuner comes out, even more gains all the way through.
ALTA2 can explain in greater detail if you need it. Thanks!
Old Feb 7, 2009 | 08:06 PM
ADAMSALTAMINI
NICE! Thanks for the biz-nez!
Old Feb 7, 2009 | 09:41 PM
Noegel's Avatar
Noegel
ALTA, with the addition of your ECU product in the future, will this take out the negative gains in the upper powerband? That would seal the deal quite nicely!
Old Feb 8, 2009 | 08:25 AM
ADAMSALTAMINI
YUP for 100%. We will move that boost target and remove the conflict where the OEM ECU pulls the boost. Additionally, we will be adding boost in many other areas of the rev band, plus timing, fuel etc.
Hope that helps!
Old Feb 8, 2009 | 06:25 PM
Noegel's Avatar
Noegel
Gorgeous response! Sign me up..
Old Feb 8, 2009 | 06:50 PM
ADAMSALTAMINI
Thanks! Now is a great time to buy online with the special coupon going on, or feel free to PM me your details and we can gladly handle any order via the phone!
Thanks again!
Old Feb 11, 2009 | 06:46 PM
Sketch's Avatar
Sketch
Man I want theeeese lol
Does the boost tube set release any more BOV or turbo sound?
Old Feb 11, 2009 | 09:02 PM
ADAMSALTAMINI
Thanks in advance for the biz-nez! No new noises with these tubes. Thanks for asking!
Old Dec 26, 2010 | 04:03 PM
*Ghost*'s Avatar
*Ghost*
Do you still make the Shorter cold side boost tube?
I can not find it on the website.
Will this fit on a 2011 JCW?
Old Dec 27, 2010 | 09:31 AM
ADAMSALTAMINI
Thanks for asking! Hot Side YES. Cold Side not right now. Might come back in the spring of 2011. Not sure on fitment on the 2011 cars.
Hope that helps and thanks for asking!
Old Mar 21, 2011 | 10:43 PM
smoke05S's Avatar
smoke05S
The JCW has larger tubes than the S stock. What kind of gains can I expect on an 09 JCW? And do you have a larger intercooler (or maybe some kind of boost tube + intercooler + software package for the JCW)?
Old Mar 22, 2011 | 08:47 AM
ADAMSALTAMINI
Thank you for your post and question!
The JCW and Cooper S both use the same plumbing on the boost side. The Inlet Hose is different, but not the boost tubes, intercooler etc.
We do offer:
Hot Side Boost Tube
Front Mount Intercooler
AccessPORT Tuning Tool
You can bundle them up OR we have some prebuilt bundles too: CLICK HERE
Hope that helps! Please let me know how I can help further!
adam @ ALTA Performance
Old Mar 22, 2011 | 08:53 AM
tvanhouten's Avatar
tvanhouten
Alta Staff,
Just so I am clear, these hose kits don't fit the 2011 MCS N18 engine, correct? They only fit the pre-2011 N14 engine?
Just want to make sure and not order something that doesn't fit.
Thanks ahead if time...
Old Mar 22, 2011 | 09:03 AM
ADAMSALTAMINI
Originally Posted by tvanhouten
Alta Staff,
Thanks for asking! All of those items also fit the 2011 MINI: CLICK HERE for the link to our site!
Always happy to help!
Old Mar 22, 2011 | 12:06 PM
yetti96's Avatar
yetti96
I have a buddy with them on His 2011 and loves them and has many praises for them.
Old Sep 9, 2011 | 08:34 AM
jakesulivan's Avatar
jakesulivan
Is there any product warranty on these things?
Old Dec 14, 2011 | 02:07 AM
Mad TKD's Avatar
Mad TKD
Hello to everyone at Alta. Enclosed is an email I have sent several times with no response. Please advise so I can get my R57 its christmas gifts
Hello Alta,
This is the 3rd or 4th time I have emailed you about more information for parts to upgrade my R57 cabrio. It seems like parts for my car are either not available or still in development. I would like your intake to put on my car if it is available. I would also like the exhaust. I would just like the cat back portion not the full exhaust that includes the down pipe from the turbo if possible. So in closing could you please tell me what parts are available for my car so I can purchase them and get them here by christmas.
David
