Drivetrain Alta header is on...
Well I got home from work tonight and ups had dropped off a package for me. It was my Alta header and a set of NGK colder plugs.
I got started right away and the wrenching began.
I took a break from working on it to eat dinner and then went out and finished it up. Took it for a ride and the first thing I noticed was she is quite a bit louder.. lol no cat, for off road use only.. Yah right.. haha
I am planning on taking it to the track this friday if the weather is good and the track is dried up from the weather from the last few days. After I got back from my little drive I changed the plugs and took it for another drive.. I really enjoy driving this car..:icon_smile:
Here are a couple pics from the install...
Bill
Bill
Bill
It fit against the head great, I tightened all that up first with no problems. Maybe the one with the cat will have a little better bend to it..
Bill
Bill
It took me about 3 hours to do, not to bad of a job. The hardest part was starting the header on the head. Holding the gasket in place and getting a couple bolts started. after that it wasn't bad..
Bill
Bill
Yes I did, but as soon as I get my new tune I will have the rear o2 turned off. That will take care of that little problem..
Bill
Bill
My little dose of LITHIUM
While I agree, where exactly would he be installing it? Notice the photo shows the catless header to be the same length as the stock header *and* cat, so unless he has a shortened cat-back system, there's no room for the cat.
But he says it's for off-road use only...
well, the 'off-road use only' doesn't wash since his car has tags on it and he commented on taking it for a ride.... so he's using it cat-less on the street. Not a good idea. If it's for the perceived performance gain he's just fooling himself.
Well, if he had the header you post the photo of, maybe, but look again at the header he actually installed. No flanges and no mid-pipe. Just solid welded tubing all the way to the second o2 bung...no cat here, and no where for it to go.
And I must agree again with rl.48.mini, the noise is amazing with no cat, but the performance gains are minimal at best, especially without a head (but then, which head is the Alta header designed to match with?) In the end, just a whole lot of feel-good SS near your right foot, and a whole lot of noise at the south end of a north facing Mini.
I'd rather be installing coilovers...oh, that's right, I just did!
I had just purchased a Comptech MINI header from Mike @ Seven. As soon as it gets back from "Jet Hot" I will get it installed.
It should look like the header to the far right when I get it back.
As a side note, I hope you let the engine cool off before changing the plugs. Otherwise, sounds like a nice mod and the system looks really nice.
How do you like the Comptech header? I'm considering buying one from Mike @ Seven as well.
Comptech install
With the Borla Race cat back bolted to the back of this header it is definitely louder. The sound comes on at about 3500 rpm and screams till redline!
Next time we have a dyno day I will put it up on the rollers to see how much extra power it makes.
As far as fit and finish go this thing is second to none!
I don't know if Mike @ Seven has any more of these lying around, but if you PM me I know a guy who has one for sale, since it won't fit his 07' MINI.
Hows the sound inside the cabin before and after the Alta Header install?
I currently have the Borla Race Exhaust and I'm thinking of adding the header for some more sound...but don't want to over do it inside the cabin. I'm really looking for more popping and burbling.
-ROB-
-ROB-
Sep 22, 2015 02:05 PM
