Drivetrain Stuff Keeps Dying
Old Mar 13, 2007 | 03:56 PM
1QKMNIS's Avatar
1QKMNIS
Stuff Keeps Dying
So in the last month it seems my electrical has gone to poo. One day my horn started acting up, sometimes it would honk, others day it wouldnt.....started getting less loud and finally just gave up. Then my door locks stopped working...first my driver side door wont open with the clicker and then a couple days later the passenger side door also stopped opening with the clicker...then the switch inside that unlocks the door stopped working all together. Lastly my trunk stopped opening so I have to stick my hand under the seat whenever I want to open it. All of it I believe electrical, i've checked all the fuses theyre all good and I took the battery to AutoZone and they said it was fine. What else could it be...did all this just break and now need to be replaced?
-Spence
Old Mar 13, 2007 | 04:12 PM
MRmidge's Avatar
MRmidge
are you still in warranty, if so get that thing in to the shop fast. If not, my heart goes out to you, electrical systems are beyond hard to diagnose, but it sounds like your connectors somewhere in the ahrness are corroded. But I could only guess where and how many of them there are.
Last edited by MRmidge; Mar 13, 2007 at 04:15 PM. Reason: saw some grammer errors, sure to find more later
Old Mar 13, 2007 | 04:16 PM
1QKMNIS's Avatar
1QKMNIS
Ive been outta warranty for about 6000 miles....ugh....this blows...
-Spence
Old Mar 13, 2007 | 05:02 PM
Sunracer's Avatar
Sunracer
Electrical
First step should always be to clean your battery terminals and cable, then check and clean all the chassis grounds you can find. You might have your alternator testedtoo, or at least put a meter on the battery with car off and car on with headlights etc on and see what voltage levels you get. PB
Old Mar 13, 2007 | 07:39 PM
Murmini's Avatar
Murmini
Also check to see if there is any wet carpet on the passenger side foot well. There have been reports of leaking on that side and the general body module, that sits behind the kick panel would suffer if there was water getting in there. The general body module controls all of the items you mentioned,.
Old Mar 13, 2007 | 08:39 PM
markldriskill's Avatar
markldriskill
Could it be your key "clicker" thingy as opposed to something in the car itself? Is there a battery in the key that dies?
Old Mar 14, 2007 | 03:14 PM
1QKMNIS's Avatar
1QKMNIS
The weird part it....the clicked will still lock the doors but it wont unlock them....like you hear the noise as if they were being unlocked but they dont actually unlock. I looked for any kind of water damage looking stuff and say nothing, looked nice and dry.
-Spence
Old Mar 14, 2007 | 09:10 PM
UKSUV's Avatar
UKSUV
Good call......ALSO....grounding modules....grounding modules...grounding modules. A schematic will show all your common parts. You might be able to narrow it down.
Old Mar 15, 2007 | 02:09 AM
Murmini's Avatar
Murmini
I have a list of all grounding points here http://www.murmini.com/pages/electrical
Old Mar 15, 2007 | 03:54 PM
1QKMNIS's Avatar
1QKMNIS
Thanks for the list! I really hope its something easy like this.
-Spence
Doc Pain
Mar 10, 2021 04:50 AM
PsychoRallye
21
Feb 17, 2019 06:08 AM
wildwestrider
11
Jan 29, 2016 05:06 PM
eliseo1981
Sep 30, 2015 07:57 PM
pkillur
Sep 26, 2015 01:57 PM
