Drivetrain If you could see through the bonnet...
Old Feb 26, 2007 | 02:27 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
you'd see this. Well, if you could see through my bonnet, this is what you'd see. Of course you can always just lift the bonnet, but then you can't see where bonnet-things are, like the grille and the scoop. Notice the (lack of) space above the DFIC, the large amount above the shock tower brace that is taken up by the bonnet liner, and the distance between grille and airbox intake duct.
Here's another from above which is not as informative, mainly because I have a DS car. Would be cooler with a colored bonnet.
I was thinking about these photos because robino has posted that his Alta V2 IC has punched dents in his bonnet. Now you can see why, since it's bigger than the M7 DFIC shown here.
btw, none of this image-making will be possible with the R56...but then that's not my problem.
Old Feb 26, 2007 | 02:55 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Phil, excellent job! Those are very cool pics.
Do you have any from the front w/DFIC?
Old Feb 26, 2007 | 03:01 PM
DrPhilGandini
None from front on, but can do! Actually I was using these to sketch up a new scoop...an integrated inlet, outlet scoop along the lines I saw on a Nissan R-34 JGTC. eg.
Not a great sketch but you may get the idea. I checked the profile see-through and an exit-diverter to the louvers would be relatively easy to fab.
And if we could afford the talent of Joel (JS) it would look fantastic (...ah, not like a festering pusstule like the Equiss) Ooops, did I say that? JMHO...
Old Feb 26, 2007 | 03:07 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Great pics!!
Old Feb 26, 2007 | 03:08 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Excellent idea(pretty damn good sketch too), the only thing is the factory offset of the IC.
How do you propose to exit it in the center of the hood?
Old Feb 26, 2007 | 05:15 PM
carbonized's Avatar
carbonized
Damned that look good!!! The under the hood exit duct can deal with " off center path " the same way the scoop does , no problem! The louvres would have to taper to the center to meet the hood center bump, no probleme! And the hood frame has to go (at least the center), no probleme! I wish I had some clay!! Dr phil
Old Feb 26, 2007 | 06:02 PM
flyboy2160's Avatar
flyboy2160
some of us will pay for these same shots of an r56
Old Feb 26, 2007 | 06:14 PM
minimarks's Avatar
minimarks
Great work! Thanks for the insights!!!
Old Feb 26, 2007 | 08:13 PM
DrPhilGandini
Actually, Joel tells me you can get a pretty good sized exit scoop without cutting the hood braces! My problem would be mating this to my FAD duct, but I'll give it a try if anyone could ever make this scoop. I don't think it has to sit all that high off the bonnet either--it could be as little as 1/2" high since the louvers would actually sit below the bonnet line and mate up with the exit diverter (which could be offset/asymetric).
Anyway, just ideas--and it's cheap to photograph, photoshop and sketch!
btw, my FAD is clearly working--I have to clean my Alta air filter at least once a month nowdays.
Old Feb 27, 2007 | 06:44 AM
minimusprime's Avatar
minimusprime
Really neat shots there phil... thanks again as usual for your informative posts. Did you just tripod the camera and pchop? If so I'll have my gf do one angled like that of my cr/bl... that way we can see the hood a bit more clearly.
Old Feb 27, 2007 | 08:03 AM
Bahamabart's Avatar
Bahamabart
Great stuff
Old Feb 27, 2007 | 09:59 AM
DrPhilGandini
Yes, it's simple: using a tripod make 2 photos, then simply overlay them in PS and blend the (top) bonnet image by moving the opacity slider. I did a bit more erasing to get it to look better, but that's just PS tinkering.
I'd like to see another color just to confirm my hypothesis that the colored bonnet would show some details and locations better, especially on the profile image.
Old Feb 27, 2007 | 10:02 AM
minimusprime
sure ill take care of it when i get home from work today.
Old Jul 17, 2007 | 05:53 PM
SteveS's Avatar
SteveS
I wonder if the Mini was designed so that there would be a certain amount of air coming thru the intercooler and out the back of the engine compartment to the underside of the car to cool the exhaust and vacate the heat on the back side of the engine. Altering the hood scoop so that it reduced the flow out the back of the engine would naturally reduce the airflow off , down and out of the engine compartment. Just wondering is all. Is there a low pressure zone on back side of the engine, from a draw off the underside of the car? Wouldnt there be a dead zone right in front of our rather steep windshield?
Old Jul 17, 2007 | 06:34 PM
Fracky's Avatar
Fracky
Transwarp - Warp 10.0
Wow, that'd be a *hot* looking scoop. At AMVIV, I saw Randy T (M7 Tuning) had an add-on to his DFIC directing the air up-&-out through his hood vent. If your idea & Randy's add-on could be put together, that'd be a product I'd buy for sure.
Old Jul 17, 2007 | 09:06 PM
Longboard Mini's Avatar
Longboard Mini
Really nice work Doc, I think the sketch looks great and blends very well with the lines of the mini.
I love the concept.
Phil, look in my gallery for the bikes. Your Giant is awesome. How much does it weight. Did you know Jan used to race.
Longboard
Old Jul 18, 2007 | 06:57 AM
brigadoonb's Avatar
brigadoonb
great photo work!
Old Jul 18, 2007 | 07:22 AM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Very Nice looking PS imaging. I like the concept that you are working on.
Old Jul 18, 2007 | 10:01 AM
DrPhilGandini
I think M7 will be offering an exit scoop, that reflects the design of the Ram Intake scoop shown in my photos. They will, however, be separate items requiring 2 holes (the OEM intake hole and an aftermarket exit hole.)
My idea was to make a single scoop, still requiring 2 holes, but covering the center section of the bonnet as sketched. I ultimately would like to do this with a CF bonnet as it could be "molded in" to the bonnet to form an integrated bulge sort of thingy.
Somehow, I think that ideas a long way off... (see my wife.) haha.
Old Jul 18, 2007 | 10:08 AM
Xiek's Avatar
Xiek
very cool pics.
Old Jul 18, 2007 | 10:58 AM
Malcon's Avatar
Malcon
this is a god idea for a scoop. i wish there was a way to do this with out messing with the bracing of the hood. im watching this one.
and if anybody whats to supply me pics of the r56 to do that to ill do it noproblem. it will take 5 min.
awesome job man!
Old Jul 18, 2007 | 11:56 AM
JS's Avatar
JS
awesome job man!
I don't think this idea would affect the underhood bracing, but then I'm not looking at a hood now. When I modelled the Exit Scoop, I made sure that I didn't interfer with the bracing.
Dr. Phil, are you proposing raising the DFIC to be more inline with the airflow?
JS
Old Jul 18, 2007 | 12:52 PM
DrPhilGandini
JS
psst, hey Joel, I thought we agreed we weren't going to mention that...
(as per the photographs sketch in Monty Python: could be..., yes..., definitely could be...)
Old Jul 18, 2007 | 01:27 PM
JS's Avatar
JS
Ops, sorry.
Old Jul 18, 2007 | 02:30 PM
herbie hind's Avatar
herbie hind
looks very nice . what provisions for water?
