I remember in the older Moss Mini catalogs, they claimed an upgraded coil pack will consistently yield 1 second quicker 0-60 times. LMAO
I remember that...Can't figure how the slight voltage increase is going to give you a second in 60 unless your old coil is just not working. Seems like there is other avenues for perfomance upgrades. Although the MDS units does looks bitchin' in red.
My MSD needed some serious modification to fit...but I won! The MINI bolts are larger in diameter than the metal sleeves molded into the plastic of the MSD. So I just drilled out the sleeves, and everything worked out fine. There's some hot plastic flying on the drill press, so be warned.
Of course, the MSD is the best, 'coz it's RED. +5HP no doubt.
