Drivetrain Aquamist Water Injection
Ask and you shall receive
No way 2 gal in the headlight washer resevoir. I didn't measure when it was out, but I'd guess about a half gallon.
This is for the headlights, I'd guess the other tank is about the same.
Matt
Matt
I didn't think so...
I have the same thing as you. Mine is dry right now. when I get home I will fill it up and let you know how much it holds.
Longboard
So there are two tanks?
One's on the right, the other's on the left...one's for xenon I think but they're both roughly the same size and sit behind the panel where the side marker is...not very large in either case...
I am still seeing the car pull a little timing at WOT...
Matt, I guess you forgot that thread I created a little over a year ago where I removed the rear wiper reservoir, and provided the weight loss. I measured the capacity to be just shy of .75 gallons.
A little bigger would be nice, plus if I'm going to put weight back on, I'd like to do so in rear...
If that's what you want...
Matt
Been gone for about a week, and trying to catch-up with so many threads!
1-what are the dimension for the Brail
2-did you have the dimension for the battery box before you cut it out.
http://www.race-sport.net/battery
I believe I still have the battery box, but maybe I tossed it... You want to know if I had the dimension of the battery box before I removed it? Not sure what you are asking for...
Yes...just wondering if you know the dimensions of the battery box
I'll PM you later and explain...
Sid, I'll take a measurement of the battery tomorrow. Actually, this might help ya!
Does the reservoir have to be rigid?
As I shared with a couple folks well over a year ago, I was contemplating using a bladder of sorts inside the rear panneling. You know, up in the cavity where there are storage compartments (each side of the boot). One could use the rear cigarette ligher hole for a fill location, or somwhere in that vicinity. I drew-up plans long ago, and just never made it happen...
I like the idea because it is in the rear, not visible, and sheltered from the warming sunlight...
And if a bladder is not ideal, I even contemplated forming something that would coutour to the available space back there. I was thinking about putting a plastic bag in this area and shooting some expanding foam into it, letting it form the shape for which I would need to create a container. I see a gallon plus being doable in this space...
My other proposed location for a reservoir is under the car. I have a straight exhaust system, so no resonator or muffler on the left or right side. I could mount something in either or both of those locations, but of course, it is near the muffler. When moving, this is not an issue... Insulation would be nice with this spot...
The easiest place for me would be where the rear seats were, under my fabricated aluminum deck that covers this large concave space. It would be out of sight there, and could be as large as anyone would want. This location is more forward though, but not much more and there is pretty good heat in this area also due its proximity to the exhaust tunnel...
Unless there is some cool, easy way to put a reservoir inside the rear panneling, I'm leaning toward a tank below the car, sheltered from heat and debris. I could easily have a fill hole in the boot area for easy access. I don't use the outboard rear exhaust hangers, so that can help with securing something.
Just thinking out loud...
Your idea about a tank underneath the car would work well. I would put it under the right rear to offset the drivers weight a little.
That's pretty cool. I didn't know you could lay the battery on it's side like that.
I just tried to call you, but got the machine.
Is that MINI decal from the file you sent me way, way back? I think that was my first mod.
just sent ya a pm. sorry, didn't have the cordless outside with me. working on the mini now actually. fun stuff like running a microphone for handsfree operation...
ah, that's a mousepad believe it or not! if you find them still available, let me know. i recently trashed mine as it saw too much sun over the years. was like 10 bucks back in the day... I still have that large image though.
since these are sla batteries, they are sealed (sealed lead acid), making orientation not so critical....
give me a couple more hours to wrap-up, and try calling again, if you like...
I think that as long as you have enough pressure going through the correct size nozzle so that the spray will reach across the core, you should be fine. Otherwise, you may need to use a bar type sprayer that extends into the core.
