Drivetrain anyone with problems with big bore throttle body
Old Jan 13, 2007 | 07:16 PM
mini22's Avatar
mini22
2 years ago i put a mini-madness 63mm throttle body on my car and it trigger the eml light and i returned the TB but i want to get a different TB cause i like the performance i got but did'nt enjoy the eml light staying on what size TB should i go with that won't trigger the eml light or how can i adjust the idle speed
Old Jan 14, 2007 | 10:01 AM
SRTech's Avatar
SRTech
To be safe, we sell the 59mm M7 TB for the 05-06 MCS and the 60mm for the 02-04 MCS. These sizes normally don't cause any problems. Given the variation between MINIs I've seen, I'm sure you can vary from these sizes in some cases with no problems.
Steve
Old Jan 14, 2007 | 11:31 AM
MarioKart's Avatar
MarioKart
Vendor
I have one and it is WORTHLESS, a total waste of money and time.
M
Old Jan 14, 2007 | 03:07 PM
SharoSC02's Avatar
SharoSC02
M
Mario, thanks for telling me that last week on the phone, you saved me some money.
Old Jan 14, 2007 | 03:11 PM
AZMCS's Avatar
AZMCS
M
Only makes sense. The TB is the least of the restrictionns in the line of prgression for the charge. Head way before one of these "vaporware" items. IMHO of course..
Old Jan 14, 2007 | 03:24 PM
SharoSC02's Avatar
SharoSC02
so far I have been told that on my 02 MCS the items that are not quiet mods that get gain for the money are DT BPV, big throttle body and 380c injectors.
I think I will have to spend my money wisely and get the best bang for the buck.
Old Jan 14, 2007 | 03:30 PM
Dr Obnxs's Avatar
Dr Obnxs
I tested a few on a close to stock car...
and didn't find any difference in power. I talked to Steve Dinan about it, and he maintains that you do get benefit when the car is modded a bit (intake, pulley exhaust....)
The larger I went, the more I had some issues with a flat spot. But as my car got more and more modified, even the stock TB has it a bit.....
Sometime I may retest the two I have (stock and 60 mm) to see if there's a difference in power now that the car is a bit more wild.....
But there are a lot that had issues with the 63 mm TB, and there are also a lot who ran it with no problem. The issues seemed to get worst with later year builds. But mine is an 02. I guess I was just lucky there!
As far as the code, what are you getting? That may give you something to go on. Idle speed is set in the ECU, and is controlled by TB position for slow variations, and I think timing changes for very fast control.
Matt
Old Jan 14, 2007 | 04:54 PM
pberry51mini's Avatar
pberry51mini
No Fear Gear
I believe my 59mm from M7 has aded some, though I have no imperical proof of such.
Unless you want to believe my highly sensitive butt dyno.
Paul
Old Jan 14, 2007 | 05:50 PM
isellem's Avatar
isellem
ive gotten about 3-4 whp with a car with a cylinder head with the throttle body that i make which is 62.5 mm
Old Jan 14, 2007 | 06:42 PM
MarioKart's Avatar
MarioKart
Vendor
Hey Sharo, if you get DT BPV it is worth the money a very good upgrade and cheap. I wanted to call you but I couldn't find your number.
M
mdutton11
14
Oct 26, 2015 01:47 PM
Indimanic
Aug 19, 2015 11:08 AM
Emnotek
Aug 13, 2015 05:47 PM
minipopkart
Aug 13, 2015 05:22 AM
