Drivetrain Dyno Charts
Old Dec 22, 2006 | 10:58 AM
  #76
Paul Webster's Avatar
Paul Webster
You going to teh dyno today Spillman
Good luck look forward to the results
Old Dec 22, 2006 | 03:20 PM
  #77
spillman's Avatar
spillman
Yet again tunning without data logging and ran into issues. Guess I will have to wait until tuesday to get back on the dyno.... Just picked up an actron and doing a little datalogging on the streets...
Old Dec 22, 2006 | 03:45 PM
  #78
Paul Webster
That must be a on the streets, better luck Tuesday, you know it'll be worth it in the end.
Old Dec 22, 2006 | 04:33 PM
  #79
spillman's Avatar
spillman
Haha yeah especially in the rain. Wheel spin in fourth gear. Hard to put a load on it.
Old Dec 22, 2006 | 04:38 PM
  #80
Paul Webster
At the europesn finals I did my first run on 175/65-15 Pirrelli P3000, I've never laughed so much 15.1 at 113
Old Jan 15, 2007 | 02:53 PM
  #81
Alex@Helix's Avatar
Alex@Helix
Model:2003
Year:Mini Cooper S
Transmission: 2005 6 speed manual
Gear Used: 4th
Dyno: Mustang MD-250
Modifications: An extremly modified car with a custom solid lifter head, water to air intercooler...etc.
Atmospheric conditions (aka Temperature, humidity, etc.): right around 50 degrees F
SAE Correction or Actual WHP:
Uncorrected 216.6 whp and 172 lb ft.
Corrected: 211.3 whp and 169.4 lb ft.
Notes: We used the correction factor on the second run to account for the extremely cold air in the dyno room at the time. This was the first non-turbo car to go above 200whp on our dyno, so he got his dyno runs for free.
Old Jan 15, 2007 | 03:29 PM
  #82
Thumper460's Avatar
Thumper460
Nice numbers !! Over 200 WHP rocks in these guys!! LOL
Does the Mustang Dyno run low numbers?? I thought I heard there is a differance in the numbers from different type dyno's?? Yes??
Just me..................................
Thumper
Old Jan 15, 2007 | 04:05 PM
  #83
cooper99's Avatar
cooper99
A few days ago I went to a shop just outside of Columbus (Dynotune) to watch my friend's beastly GT28R turbo VW GTI get dyno tuned. It was a good learning experience.
From what I was told...
The industry standard is the Dynojet dyno. It is the most common dyno in the USA and what most aftermarket shops refer to when comparing power. The dynojet software lets you pick from SAE corrected, std, or actual whp.
A Mustang type dyno gives its version of whp, which is usually 10-15% lower than the Dynojet sae hp. Apparantly there is a program out for mustang dyno owners to convert their numbers to dynojet numbers.
Old Jan 15, 2007 | 04:15 PM
  #84
AZMCS's Avatar
AZMCS
cue: Can of Worms Opening......
Old Jan 15, 2007 | 05:52 PM
  #85
Thumper460's Avatar
Thumper460
cool.. that is about what I heard.
Thumper
Old Jan 15, 2007 | 06:40 PM
  #86
Cosmic Purple's Avatar
Cosmic Purple
Peace,
I see the numbers are out on the CosmicPurple. As far as the differences in dynos... This car dynoed at 238 whp on a dynojet in the same week it dynoed on Helix's Mustang at 194 whp with the same engine mods as today. On both days temps were in the low 90's. Thanks for the free dyno Eric!!! I wonder what the winter time dynojet numbers are?
Old Jan 15, 2007 | 06:58 PM
  #87
Cosmic Purple
Originally Posted by iggy
Model:2003
Year:Mini Cooper S
Gear Used: 4th
By the way, I was trying to have Eric rev it up to the limiter but he stopped at 7300 RPM. And i'm not sure the correction factor had anything to do with temps. It's the old Helix uncorrected chart at 211 and the new corrections at 216. After charting 194 as the highest non turbo/ tc the 1st time, i was looking forward to the Helix challenge on a better day. Thanks again Eric.
Old Jan 16, 2007 | 02:20 AM
  #88
MadMick's Avatar
MadMick
I just updated my posting with a new dynosheet,
take a look:
https://www.northamericanmotoring.co...9&postcount=61
Old Jan 22, 2007 | 03:01 PM
  #89
DarkMiniCooperS's Avatar
DarkMiniCooperS
Here is my dyno run for the following mods:
-Helix 19% pullley
-JCW 380cc injectors
-GIAC ecu
-Forge intercooler
-Alta CAI
-One-ball exhaust mod
187whp & 159 lb-ft = 213hp & 181 lb-ft at flywheel.
Great job Helix!!
Old Jan 23, 2007 | 01:02 PM
  #90
blumini's Avatar
blumini
04 blumini dyno run
Just finished installing Stage II head and put her on a dyno last Friday.
Conditions: 60 deg. Clear. Car was still hot after 100 mile commute.
Runs 1 & 2 were baseline runs performed before Stage II head install.
218 WHP
179 WTQ
very pleased
See attached for specs
File Type: doc
Old Jan 23, 2007 | 02:19 PM
  #91
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
Darn it--for me this just shows how much I'd get with a new head...I have nearly everything else, and about the same WHP as your "before" showed.
Good one, blumini!!!
Old Jan 23, 2007 | 02:26 PM
  #92
Thumper460's Avatar
Thumper460
Yep... it seems to be the HEAD as the 200+ whp getter!! Killer numbers!!
Thumper
Old Jan 23, 2007 | 05:41 PM
  #93
minigolf's Avatar
minigolf
Model: MINI Cooper S
Year: April 2004
Transmission: 6 speed manual
Gear Used: 4
Dyno: Dyno Dynamics
Modifications: ALTA CAI + Milltek cat-back
Atmospheric conditions (aka Temperature, humidity, etc.): 15°C (59°F)
Actual WHP: 115.3kW (154.6bhp)
I've been through all this before too:
http://www.mini2.com/forum/mini-coop...-theorise.html
For what it's worth dmh makes some good points on comparing dyno plots. It's a pretty futile excercise. On the same day with the same dyno and same operator my stock MCS got 106kW and a friend's got 118kW. Both stock, his was about one year older than mine. So varying results from factory are prone to skewing dyno results somewhat. Still, it's fun enough posting the results.
I've not taken my car back on the dyno since fitting a 15% pulley and MTH tuner file about 4,500kms ago.
Old Jan 23, 2007 | 06:00 PM
  #94
VurnB's Avatar
VurnB
Originally Posted by Cosmic Purple
Peace,
Wow, what was the ambient temp of today's dyno. It's amazing what cold air density will do for a mini. Pardon me if I've missed it, but do you have a list of mods somewhere?
Old Jan 23, 2007 | 07:51 PM
  #95
Brain1.0's Avatar
Brain1.0
Manufacturer
Here is one from today
Turbo conversion
20psi
pump gas
cat in place
Old Jan 23, 2007 | 08:02 PM
  #96
kapps's Avatar
kapps
Originally Posted by blumini
Re-directed
Just finished installing new head and put her on a dyno last Friday.
218 RWHP
179 RWTQ
very pleased
Man that's a lot of RWHP for a FWD car
Old Jan 23, 2007 | 08:13 PM
  #97
Cosmic Purple
Cosmic Mods
Helix CAI
M7 16% pulley
BBR Cosworth fixed tension belt drive
Pilo/DPR Head w/larger exhaust valves
titanium valve retainers
BBR Solid Tappet Assembly fitted by DPR
BBR Evo Software
Dinan TB
Mini Madness Water to Air IC
Madness Header
Borla Street
SPEC 3+
06 tranny
And much more...
Old Jan 24, 2007 | 08:50 PM
  #98
jymontoya's Avatar
jymontoya
bluemini... nice wheels
Old Jan 25, 2007 | 06:10 AM
  #99
DrPhilGandini
Cheez and Rice!!
sweet,
Turbo conversion
20psi
pump gas
cat in place
... plot of over 300WHP!!...
Old Jan 25, 2007 | 10:52 AM
  #100
Dalbi's Avatar
Dalbi
M7 Cosworth Stage2 Bigvalve head
Hello We are Dalbi R&D in South Korea.
This is M7 Cosworth full tuned Demo Car's latest Dyno Chart.
Not SAE and Smoothing is 5.
Basically M7 Cosworth Stage 2 + some more mod
ECU mapping was logically JCW OEM(this car was 05 JCW)
Dyno facillty is Pross Korea equipped with Dyno jet. They are famous with
lowest HP number in korea.
Thank you for your support Peter. I'm back now and will contact you ASAP.
