Drivetrain IC boot install help
Old Nov 27, 2006 | 02:48 PM
COR BLMY's Avatar
COR BLMY
I have done ALL of the many mods to my car and others as well.
I really do feel capable and quite confident in the garage ...
HOW DO YOU GET THE ALTA BOOTS ON ???
I do have a large intercooler and got the Alta boots to help support it and ....yes I like RED.
I can't get those things on ...
Any tips ?
Old Nov 27, 2006 | 02:54 PM
RA080624's Avatar
RA080624
brute force
Old Nov 27, 2006 | 03:10 PM
COR BLMY's Avatar
COR BLMY
Thats kinda what I figured ...
Brute force ... a couple of cuss words ... maybe even kick the dog
I'll go at it when I am pissed off at something / one next time .
Old Nov 27, 2006 | 03:30 PM
MSFITOY's Avatar
MSFITOY
Brute force? With the clamps off, place the boot on the driver side first and slide IC all the way in until the two metal throats touch...lift up the IC slightly on the passenger side and insert the boot first onto the output end of the SC...then lower the IC slowly while lifting the boot opening and bring the two down like a draw bridge until the boot slips in...then slide the IC towards the passenger side until it's in the middle then apply clamps...
Old Nov 27, 2006 | 03:37 PM
COR BLMY's Avatar
COR BLMY
They way you say it just sounds so smooth and effortless...
Maybe my outlook should be more ZEN
So I'lll start with Zen ... and once P*SS*ed off go with plan B
Old Nov 27, 2006 | 03:48 PM
MSFITOY's Avatar
MSFITOY
Do you have a standard or DFIC type of IC? If so, this should be a breeze...I do it all the time...If you have the Alta TMIC which is slightly wider, then that's another story...
Old Nov 27, 2006 | 03:52 PM
COR BLMY's Avatar
COR BLMY
It is the big flat alta 9 hamburger patty version
Old Nov 27, 2006 | 03:56 PM
MSFITOY's Avatar
MSFITOY
My condolances...it was hard enought to place the soft OEM boots on that let alone the rigid silicone version...
Old Nov 27, 2006 | 04:05 PM
COR BLMY's Avatar
COR BLMY
So ... plan B it is
or look on the marketplace for some RED BOOTS
That is why it didn't come with them or was pushed as an option.
Old Nov 27, 2006 | 04:39 PM
XAlfa's Avatar
XAlfa
I'll take 'em, if you haven't hacked them to pieces yet... Seriously, I'm about to swap ICs and am local, so let me know.
Old Nov 27, 2006 | 10:50 PM
batrugger's Avatar
batrugger
I used water with a little dish soap to lube up the parts, made them slide together a lot easier
Old Nov 27, 2006 | 11:04 PM
COR BLMY's Avatar
COR BLMY
I am going to try ONE MORE TIME.
No they arn't hacked up because that is not how I work...
If it just isn't going to happen ... they are yours (I drink good beer)
Old Nov 28, 2006 | 06:24 AM
obehave's Avatar
obehave
Didn't see this mentioned but it helps a ton if you warm them up.
I use a heat gun but a microwave might work well too.
Get them about as hot as you can stand it to start and in a few minutes you'll be good and they're on.
I have the GTT units and they're very thick too. Warming them helps a ton.
Old Nov 28, 2006 | 07:14 AM
Bahamabart's Avatar
Bahamabart
its a combination of all of the above - .
I found that two sets of hands facilitates the process.
one person pushes the IC in or on to the first horn all the way.
second person places 2nd boot onto the second horn.
As the first person lowers the IC unit into place, the second person works on getting the second boot onto the IC. I used two screw drivers w/ flat heads to help get the second boot over and on the IC. You have to be real careful not to damage the boot !
Pinched fingers - absolutely.
Old Nov 28, 2006 | 02:43 PM
Larry Clemens's Avatar
Larry Clemens
Get the new boots from M7 and you should not have any problems.
Old Nov 28, 2006 | 05:18 PM
obehave's Avatar
obehave
TBH I have no problems with my GTT boots. Warming just makes it easier.
Probably less than 5 minutes to get the boots on and IC in place. Installing the clamps takes a lot longer.
Old Nov 28, 2006 | 06:04 PM
M7's Avatar
M7
Thank you Larry.....
When we set out to make our IC boots, many of our customers told me that
if they where anything like.......(you insert the name) boots, I would get many angry calls from irrate customers... So we sat down looked at the competitions boots, and found them stiff and unweildy, but with a different
durometer silicone and a better designed polyester webbing our new boots
are comparably supple, and very easy to install......
Only available in Glossy black for now, Red and Blue in January.
Price for a set: $29.99
Peter
Team M7
562-608-8123
Old Nov 28, 2006 | 06:58 PM
COR BLMY's Avatar
COR BLMY
Thanks Peter...
and to think I was on the phone with you yesterday.
I will try these an probably wait for RED
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
adrchn
Aug 13, 2019 02:11 AM
squawSkiBum
Oct 2, 2015 09:21 AM
jziran
Aug 24, 2015 04:50 PM
