Drivetrain How much boost are you running? (stock blower only)
Old Nov 13, 2006 | 02:52 PM
MarioKart's Avatar
MarioKart
Vendor
I wondering if the M45 blower can produce more that 18psi with any combo of pulley and crank pulley. I'm running at 17.5psi with a 17% Alta and an OEM crank pulley.
M
Old Nov 13, 2006 | 03:00 PM
Ralph@Helix's Avatar
Ralph@Helix
i'm hitting 18psi with the colder weather now, usually it throws an overboost code though
Old Nov 13, 2006 | 03:09 PM
not-so-rednwhitecooper
21-22psi max in 4th gear redline.
Old Nov 13, 2006 | 03:11 PM
MarioKart's Avatar
MarioKart
Vendor
what set up do you have? and location?
Old Nov 13, 2006 | 03:23 PM
JSWMCS's Avatar
JSWMCS
boost
it may very well be the accuracy of their gauges!!!!
i can tell you Defi gauges are very accurate reading gauges.
most others are very off. the cheaper they are the less accurate as a good rule of thumb....
Old Nov 13, 2006 | 03:24 PM
JSWMCS's Avatar
JSWMCS
using a scan tool and looking at the map sensor reading is the best way to see whats going on in terms of boost ouput of the super charger.
Old Nov 13, 2006 | 03:32 PM
JSWMCS's Avatar
JSWMCS
not trying to insult anyone but auto meter are really bad when it comes to accuracy. i've had experiences installing many different brand gauges out there. the other thing is on the exhaust side of the equation affects boost too. i.e. free flow exhaust and header = less boost more cfm flow = more hp.
Old Nov 13, 2006 | 04:05 PM
polizei's Avatar
polizei
Please try not to double or triple post....just click the edit button.
Anyway, I'm not sure why you want to know who has the most boost, because like JSW said, power isn't all about just boost. Free-flowing parts (intake, exhaust, header, DFIC, etc) will actually lower the boost, but you will gain more power. At least, this is what I've gotten from reading these forums for a little while.
-Cody
Old Nov 13, 2006 | 04:53 PM
Johan's Avatar
Johan
About 15-16...sometimes 18-19 in 4th at redline...I think the air is superheated at this amount of boost though(on an m45 SC) I would like to do a back to back dyno run with a 19% then change out to a 15 and 2 combo and measure HP/TQ vs IAT...someday
Old Nov 13, 2006 | 04:58 PM
MarioKart's Avatar
MarioKart
Vendor
Anyway, I'm not sure why you want to know who has the most boost, because like JCW said, power isn't all about just boost. Free-flowing parts (intake, exhaust, header, DFIC, etc) will actually lower the boost, but you will gain more power. At least, this is what I've gotten from reading these forums for a little while.
-Cody
I didn't say I wanted to know how has the most, I just wanted to know what people are doing. And yes I know about "Free Flowing Parts" I have most of them already. Also take it easy on JSWMCS, he has good info to offer other many owners.
Old Nov 13, 2006 | 07:18 PM
JSWMCS's Avatar
JSWMCS
thanks mario
thanks mario your right i'm just here to learn and help anyone with what i've learned while building my mini.
I'll do just about anything to make more POWER
Old Nov 13, 2006 | 07:21 PM
mdsbrain's Avatar
mdsbrain
According to my Autometer gauge 15-16psi with a 15% pulley.
Old Nov 13, 2006 | 08:39 PM
BFG9000's Avatar
BFG9000
Andy posted this graph here: https://www.northamericanmotoring.co...7&postcount=21
I do manage to trip the DSC overboost light with a 19%, and that only happens if over 18+ psi.
Old Nov 13, 2006 | 09:20 PM
thats with a 19+4
Its accurate. I wouldnt post it if I didnt have real numbers.
Oh yeah, i dont run a bypass valve either, just a blockoff plate.
Old Nov 13, 2006 | 09:50 PM
Bster's Avatar
Bster
Actually, not that true. Defi meters will show 0.1 boost more than actual boost on the dyno... but it's still alright!
Old Nov 14, 2006 | 12:23 AM
MarioKart's Avatar
MarioKart
Vendor
thats with a 19+4
What does not having a bypass valve do for you? So is your car always on boost?
M
Old Nov 14, 2006 | 12:26 AM
No, but at an idle i pull less vaccum than normal, and when im in boost i stay in boost much longer than before. plus theres no boost bleed off when only going partial throttle.
i wouldnt recomend it, i get under 22mpg with my car the way it sits now
also, the car lopes a bit at an idle, especialy after just coming to a complete stop.
Old Nov 14, 2006 | 04:31 AM
Ralph@Helix
M
kills your fuel economy .. but i do like the idea of staying on boost longer, definitely pretty cool not-so-rednwhitecooper
Old Nov 14, 2006 | 04:40 AM
SpiderX's Avatar
SpiderX
I have the Detroit tuned bypass valve and I am getting 24.4 last tank with all the mods and the 62... I think that is pretty good
Old Nov 14, 2006 | 03:06 PM
JSWMCS's Avatar
JSWMCS
is detroit tuned bypass valve on a retailers/vendors website??
Old Nov 14, 2006 | 04:12 PM
fishbulb's Avatar
fishbulb
http://www.detroittuned.com/products...20050219173947
Old Nov 14, 2006 | 04:33 PM
Soul Coughing's Avatar
Soul Coughing
how many codes are you tripping?
you will get higher IAT's with your lack of a bypass valve... i wonder how much that effects your performance
Old Nov 24, 2006 | 02:09 PM
jibeho's Avatar
jibeho
I do manage to trip the DC over boost light with a 19%, and that only happens if over 18+ psi.
Does this code clear it's self or do you need to have someone reset it? Mostly thinking about the light. I just bought the ALTA 17% and I'm set for an install nest month.
Old Nov 24, 2006 | 05:23 PM
90STX's Avatar
90STX
It clears itself after several restarts. 17% probably won't trip it anyways.
Scott
90SM
Old Nov 25, 2006 | 04:30 AM
SpiderX's Avatar
SpiderX
I suggest a scan tool to read and delete codes..... modded cars are more likely to throw codes.... and it is good to know what they are.....
are any of you monitoring your air/fuel.... with all this boost etc I'm wondering how many are running lean.....
"too lean = car runs great right until it blows up"
leaning out the MCS engine can get you 10 whp (or more) just wondering what a/f you are all running as I make some decisions...
