Drivetrain Rattling from pulley belt tensioner -- Cause?
Old Nov 6, 2006 | 10:26 AM
RED FURY's Avatar
RED FURY
I have some serious rattle-chatter from my belt tensioner on my 15% puley belt Especially at idle
Any cause or fixes known ?
Old Nov 6, 2006 | 10:30 AM
Mini Works's Avatar
Mini Works
Hello,
Maybe a bearing going bad?
I have installed a few of these, both on street and race cars,
http://www.miniworks.com/gtttepu.html
Victor
Old Nov 6, 2006 | 11:33 AM
RED FURY's Avatar
RED FURY
Hi Victor,
Should I install one of these or just go with a stock replacement for occasional track use ?
Is that the overseas unit from Garrett ? Not sure on the name or spelling ?
Phil
Old Nov 6, 2006 | 11:45 AM
Mini Works's Avatar
Mini Works
Hello Phil,
I think this is a great addition to any car with an aftermarket pulley,
We have done many cars where we replaced both the idler pulley and the tensioner pulley with the GTT pulleys.
Better bearings and better quality pulleys, for piece of mind.
Victor
Old Nov 6, 2006 | 12:00 PM
RED FURY's Avatar
RED FURY
Victor,
If the Dealership doesn't replace mine for free, I will be calling tomorrow
Thanks for your help ... Phil Munschauer
Old Nov 6, 2006 | 12:03 PM
whskysouth's Avatar
whskysouth
I had the same noise from my S/C. It ended up being the shaft on the front nose of the S/C being bad due to the pulley not being installed correctly. The issue was not a bad pulley.
Old Nov 7, 2006 | 09:20 AM
RED FURY's Avatar
RED FURY
UpDate: it was the tensioner ...A "bushing" had come apart, the rest was rattling around
It is being replaced, under warranty, of course !!! Thanks
Old Nov 7, 2006 | 12:21 PM
polizei's Avatar
polizei
Hey Phil, when you go back tell Curt I said hi! This is Cody, I used to work there (hence where I met you at, if you remember that is...)
Thanks!
-Cody
Old Nov 8, 2006 | 01:09 PM
SCA's Avatar
SCA
Same thing happened to me
I had the same exact thing about a month ago. Bushing on the tensioner disintegrated. I was a little worried they might try to tell me it was because of my Alta 2% crank pulley (r or some such BS), but they never said a word and replaced it under warranty.
Old Nov 8, 2006 | 01:25 PM
SumWon's Avatar
SumWon
I can't picture which bushing you guys are talking about failing, can you help me out? Here is a picture of the tensioner positioned as it would sit on the car, can you point out the part that is failing?
Old Nov 15, 2006 | 03:51 PM
daemon2's Avatar
daemon2
I have this rattle coming from my tensioner after installing the M7 16% pulley.
It is bad when the car is cold and goes away after a few minutes at idle.
Did anyone figure out what bushing was discussed above?
BernieCoop
Sep 10, 2021 03:15 AM
patsum
26
May 29, 2021 06:29 PM
Camaro108
Sep 9, 2015 04:37 PM
Camaro108
Sep 9, 2015 01:56 PM
