Drivetrain Hood Vents-part 3
Old Nov 10, 2006 | 09:57 AM
  #151
Partsman's Avatar
Partsman
Legion_of_Doom
Originally Posted by Bahamabart
The problem for you , me and MSFITOY is that we ALREADY made holes in our the hoods. Ideally a large exit vent on the left and then an intake scoop on the right.
I should have a airbox scoop to mess with soon.
My vents were installed just as that, to vent the hot air out while sitting still and after shut down.
I don't think I would try to send the air exiting the IC up and out through the hood. I would rather send it down to the header area and use the down draft that occurs to help pull it out.
Old Nov 10, 2006 | 02:56 PM
  #152
Bahamabart's Avatar
Bahamabart
Either way the air is going to go some place!
Old Nov 10, 2006 | 03:07 PM
  #153
Bahamabart's Avatar
Bahamabart
Once you got 1 small hole in your hood - its hard not to make'm bigger . I picked these up not knowing the dimensiones and when I took them out, I said holly SH#T. Left them in the box and was yapping to MSFITOY who said - lets see what ya got!
Here they are MSFITOY
If I install I will need to lose the window pissers - due to the existing holes but could relocate on pisser in the center.
Old Nov 10, 2006 | 06:35 PM
  #154
Partsman's Avatar
Partsman
Legion_of_Doom
Those would do the trick!
Just be careful on the depth of those, there is hood bracing in the pisser area.
Old Nov 10, 2006 | 06:54 PM
  #155
obehave's Avatar
obehave
Holey Evo Bartman
Old Nov 10, 2006 | 06:59 PM
  #156
not-so-rednwhitecooper
Make sure to post some pics.
Tee hee wait till you see the turbo. just got it back. its soo purdy.
Old Nov 10, 2006 | 07:13 PM
  #157
MSFITOY's Avatar
MSFITOY
Bart...I'll personally give you my set of "brass *****" if you do it I woulda install them if they were in my hands...
Old Nov 10, 2006 | 07:50 PM
  #158
herbie hind's Avatar
herbie hind
Mounting a scoop above the airbox is not out of the question, I just need to integrate it into the vent on that side so it doesn't look too busy, or fussy as you designer guys say.
How would that look?
hey the vents look good .
Old Nov 10, 2006 | 07:53 PM
  #159
herbie hind
some old timer's gonna louver the hood on one of these cars some day .you know that yeah?
Old Nov 10, 2006 | 07:56 PM
  #160
herbie hind
holy crap i can't stop laughing.
Old Nov 10, 2006 | 08:02 PM
  #161
Partsman's Avatar
Partsman
Legion_of_Doom
Get out the camera and start snappin'
Old Nov 10, 2006 | 08:03 PM
  #162
Partsman's Avatar
Partsman
Legion_of_Doom
Thanks man. They work good too.
Old Nov 10, 2006 | 08:13 PM
  #163
i will soon. i kinda wanted to wait and suprise everyone with a turbo and a manifold.
we will see if i feel like taking pics of it tomorrow.
Turbonetics T3 50 Trim .50 a/r
hehe
Old Nov 10, 2006 | 08:32 PM
  #164
Partsman's Avatar
Partsman
Legion_of_Doom
That sounds cool.
Why don't you just fab a zoomie to come up and go into one, and bolt the turbo to that? You won't even have to put the cowl scoop on, you can just notch the hood like they did back in the day to clear a 6-71.
Old Nov 10, 2006 | 08:35 PM
  #165
well im stil working out some details, but it might not come to a cowl anymore.
looking at some pics of the cars ive seen, i might try and put the turbo over where the airbox is currently and not have to move any of the bottles or containers bolted to the firewall.
Old Nov 10, 2006 | 08:39 PM
  #166
Partsman's Avatar
Partsman
Legion_of_Doom
Whatever works for you man. Just post some pics when you can.
Old Nov 11, 2006 | 05:00 AM
  #167
Bahamabart's Avatar
Bahamabart
Why is it I feel like its the dark side of the force talking to me . Sorta like give it to MIKIE he'll try anything! No doubt, I will need several sets of brass ***** to do this - yours and proabably some others .
Old Nov 11, 2006 | 05:03 AM
  #168
stevecars60's Avatar
stevecars60
Some of us old timer's know that punching louvers in a modern hood requires removing the hood support & the possibility of screwing the whole hood up.
The other possibility is to do something like Msfitoy, only have a panel made the to your spec. Want 140 louvers, 70 on each side? No problem. 10" wide? Maybe. Then - take the fabed panel & tig it on to the hood. Yes you need to respray but you would need to strip the hood before having louvers punched anyway.
Old Nov 11, 2006 | 06:06 AM
  #169
Bahamabart's Avatar
Bahamabart
I already nibbled my hood bracing to get the first set in. I have a feekling MSFITOY would say "SO whats a little more" . These suckers are steel and a heavy gauge - probably serve as vents and hood brace all in one .
I'm gonna have to make some templates to see if I am totally out of my mind. I figure if I really screw it up well time for a carbon fiber hood I was hoping not to be the first in the hood vent club to have to buy a second hood however seems like I am in the lead .
Old Nov 11, 2006 | 07:13 AM
  #170
stevecars60
Not to worry, you're not #1 yet. It might be worth your while to take the vents you have & the car to a good metal person to have a little contour bent in to them. They look pretty flat & there is enough curve in the hood that they would distort the original shape too much.
Old Nov 11, 2006 | 07:26 AM
  #171
Partsman's Avatar
Partsman
Legion_of_Doom
Bart, maybe you should try something a little less heavy duty...
Old Nov 11, 2006 | 07:44 AM
  #172
Partsman's Avatar
Partsman
Legion_of_Doom
I think Steve's right. If they are that heavy, they may distort the hood.
Try some from the hood on a '02 Viper GTS.
Old Nov 20, 2006 | 06:17 PM
  #173
Partsman's Avatar
Partsman
Legion_of_Doom
One thing I have noticed with hood vents installed is that the SC outlet horn doesn't feel as hot as it used to. I popped the hood as soon as I shut it down, and it was only a little warm.
Sid? Bart? You guys notice this?
Old Nov 20, 2006 | 07:51 PM
  #174
MSFITOY's Avatar
MSFITOY
Chillin here dOOde
Old Nov 21, 2006 | 05:04 AM
  #175
obehave's Avatar
obehave
Thought you hood slicers might like this.
They come wide or narrow. Carbon Fiber Oooooooooo
http://www.racerpartswholesale.com/gentech1.htm
